beo sound moment
This post has 87 Replies | 4 Followers
Paul cheacker
Spain
Posts 130
Paul cheacker Posted: Sun, Mar 3 2019 9:17 AM
Hi, I bought a beo sound moment off of ebay in January so decided to buy the wall stand. whilst installing the stand and putting the cables inside the wall to make a clean look, the beo sound moment was unplugged for two days. after replugging it in now the screen is just blank. its been on charge over night and still nothing. is this correct what I've been reading that this is a known issue and it will need to be repaired. to me thats incredible i have never had a product in my life before whereby being off charge it needs to be repaired. if this is so, how much will this cost. its very nearly turned me off of b and o and on to sonos.
if anyone knows how to fix this, or how much it costs can you please advise me. thanks
Current b and o Products
beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Mar 3 2019 12:07 PM
I recall that people had similar problems and it’s not necessarily something that need repair.
Search the forum and you may find some advice.
Have you tried a reset by pushing a pin in the little hole on the long side of the tablet?
Paul cheacker
Spain
Posts 130
Hiort,
I have read a lot on the forums about this issue, I've tired resting it using the small hole in the the top. Nothing happens, I ve reset the moment and the jukebox nothing happed. I can not understand why a brand of this quality when the battery discharges you can't get it to recharge. I have never in my life experienced a product from any manufacturer that has this issue. Like I said I've searched the forums I can't find a solution so if anyone has one id appreciate it. however if this does prove to be a repair issue and I have to pay it will be the very last product from B and O i ever purchase.
James1980
Posts 80
My moment has discharged fully on multiple occasions and I’ve never had this issue. It would seem a repair is needed to me.
Beovision 10, Beoplay V1, Beolab 17, Beolab 9, Beolab 4,  Beosound 2, Beosound Moment x 2,  Beoplay M3, Beogram 1700
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Mar 3 2019 4:46 PM
Here is a thread with similar problem.
He had to repair it. Seamed the seller sold you a lemon unfortunately.
Paul cheacker
Spain
Posts 130
I have sent a message to the AMGRACE the bang and olufsen shop in leamington Spa where I bought it from, as I do not feel this is fair. Now I see the reason B and O discontinued this product seems like a lot of people have had the same issue. Lets see what the shop says. However if this becomes a repair issue I have to pay for then after being a B and O shopper I will sell my products and move to another brand.
However Im going to see what they say first.
Paul cheacker
Spain
Posts 130
Fansastic
The Hague, The Netherlands
Posts 768
Hiort:
I first thought the battery died, but a quick check at the dealer ruled that out. Happend just out of the blue, do not think that the former owner had knowledge of this.
Have you tried to leave the tablet of the moment for a day and then recharge it and tried to reset is with the pin? I had a non responsive tablet once before and as I remember this made the tablet responsive again.
I understand your frustrations, but I’m enjoying the Moment every time I use it! Back in the days I bought a brand new BS3000 and within a year it needed the laser to be replaced. After that till now not a worry in the world and still use it. Don’t let one faulty part spoil the pleasure of the product.
Paul cheacker
Spain
Posts 130
Do you mean take it off the charger again leave it for a day then put it back on charge.
Paul cheacker
Spain
Posts 130
Fansastic
Posts 768
Paul cheacker:
Yes, leave it off and after a day, put it on the charger for a short time so it gets a bit of charge and see if it starts up again, if not try the pin reset and then see if it starts up again.
Paul cheacker
Spain
Posts 130
Well I basically did everything people said and still dead no response what so ever. So I decided to contact the Bang and Olufsen shop I brought it from which was B and O in Leamington Spar. Well the response just shows me what B and O think about customer service. The reply is below, and although I understand that its going to need to be repaired, this item was brought two months ago from a B and O dealer and although second hand not even an offer towards some of the costs. This has taught me a valuable lesson, I will have to get the Beosound moment jukebox fixed but it will be the last item I ever buy from this brand and I have been buying things for the last 15 years.
Below is the B and O shop response. Great service.
Sorry to hear that the Jukebox isn't charging. It's worth checking that the contact between the two components is good. In some cases performing a reset on the Jukebox might work but the likelihood is that the internal battery on the Jukebox requires replacing,
With BeoSound Moment, the servicing proceedure is to take the system (I would suggest the Soundheart as well) to your dealer of choice.
They should send the combination to the Bang & Olufsen designated Service Centre based in Northern Germany. As it would be a chargeable repair you may be asked for a fee upfront to cover the cost of providing a quotation for you.
The process usually takes around 2-3 weeks.
In Valencia, here is the link to the dealer in the city:
https://stores.bang-olufsen.com/en/spain/valencia/gran-via-marques-del-turia-75
Hope that this info helps.
Kind Regards
Steve Jones | Sales Executive
BANG & OLUFSEN
Bang & Olufsen of Leamington Spa
78 Regent Street | Leamington Spa | Warwickshire | CV32 4NS | UK
Phone: 01926 881500 | Mobile: +44 7940 263256| Whatsapp
E-mail: leamington@amgrace.co.uk
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Mar 6 2019 11:49 AM
If you bought it from a shop you should have some warranty. Even for used stuff. Minimum 6 months.
Ralf
Duels
England
Posts 2,553
Duels replied on Wed, Mar 6 2019 12:35 PM
How old is the moment itself? And was the shop selling it themselves second hand or on behalf of a customer?
Millemissen
Flensborg, Denmark
Posts 14,680
Paul cheacker:
That might be the last item I would buy off ebay!
marexy
Posts 710
marexy replied on Wed, Mar 6 2019 1:59 PM
I did want to buy Moment
and regarding all problems ..i think not ..and it's not possible to repair it on component level ..as many new B&O items.
As BL4 power amp PCB.. hey 130€ for 5x7cm electronic board ..are you MAD..wt..f.
Paul cheacker
Spain
Posts 130
Hi Millemissen you should of read my last enter it was bought on ebay from B and O Leamington Spar shop, a lot of B and O shops sell products on ebay. So yeah Im right to be angry and I have rights under uk law. which I have wrote to the shop about and are awaiting an answer.
Paul cheacker
Spain
Posts 130
I bought it in January it is 3 years old and it was not mentioned to me at ll or in the listing who it was being sold on behalf of.
Millemissen
Flensborg, Denmark
Posts 14,680
Paul cheacker:
Ok - then!
But as Ralf wrote, ‘If you bought it from a shop you should have some warranty. Even for used stuff. Minimum 6 months.’
Then why is the dealer talking about some ‘fee upfront’?
Warranty is not just a UK thing - Spain is in the EU and it is the same there. I guess that is not different, when a dealer sells off ebay.
Paul cheacker
Spain
Posts 130
Anyway Ive taken it back to a B and O dealer in Valencia Spain where I live, lets see the outcome. Depending on this, can someone advise me if there is a set of headphones that can be linked to the moment to wirelessly listen to music
Hate to be the cranky realist here but the moment is the worst product B&O has ever made.
The moment can't do anything an iPad with a cheap NAS/Sonos can't do, for 1/10th the cost. I'd suggest getting your money back if you can.
BeoLab 18's. Beolab 3's. A8. A9. A2. H7.
Paul cheacker
Spain
Posts 130
Well I guess in life we all have our own personal opinons, I myself like the moment alot.
So my question is there away to connect wireless headphones with the moment if so does anyone know which ones?
poodleboy
Posts 303
poodleboy replied on Sun, Mar 17 2019 9:14 PM
Paul cheacker:
I would think being functional and reliable would be conditions for liking it alot, or did I miss a post?
Sandyb
Posts 2,186
Sandyb replied on Sun, Mar 17 2019 10:59 PM
It works pretty well now and has done for the last year or so.
But it’s not a very good product by design though.
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Mar 18 2019 11:25 AM
Paul cheacker:
There is not.
Moment is not sending anything over Bluetooth. Just receiving.
Did you get your problems sorted?
Paul cheacker
Spain
Posts 130
Well after 4 weeks of being sent places I finally get an answer, and that answer is a total replacement of the jukebox costing 520 euros. Wow the shop in the uk did a good one on me. My trust in buying second hand from a b and o shop has gone. The repair shop in Germany, because of the model had to be sent to Germany stated the untit had been drop sometime in it life. Not by me.... but the oak side had a mark i put that down to wear and tear. Anyway the choice is pay the money or have a door stop. Im going to write to the citizens advice to check what my rights are. Ive contact the b and o shop in the uk but they dont respond. Seems like these days customer service is not that important to some shops (not all) but some.
Beophile
USA
Posts 41
Beophile replied on Tue, Apr 23 2019 11:38 PM
Unfortunately, my Moment just experienced exactly the same issue. That is, my Moment was working fine when I unplugged the power cable of the Soundheart with the Jukebox still on the Soundheart.  After a couple of weeks with the Soundheart being without power, I went to resetup the Moment.  The Jukebox was unresponsive, but I assumed it was discharged so I plugged in the power cable of the Soundheart.  After days of trying to charge the Jukebox, the Jukebox would not come back to life (although the Soundheart appears to be functioning properly).  That is, the screen remains dark and the Soundheart (as far as I can tell) does not see the Jukebox.  I believe I’m a month or so out of the 3 year warranty, so it looks like I’ll have to spend $800 to replace the Jukebox.
Aussie Michael
Melbourne, AU
Posts 3,730
Severed_Hand_of_Skywalker:
The encore tops the list i think
marexy
Posts 710
marexy replied on Wed, Apr 24 2019 12:05 PM
So sorry for all you with no luck on BSM.
I did want to purchase BSM some time ago
That is why i still have BS9000 mk3 FM, CD on aux + all moden add-ons on the music server.
intrernet radio, streaming spotify, deezer, tidal , 3tb music disc, ripping,yoube , can be wisa with USB support...ect...
Hi END D/A conveter that make total difference in music. And i think TIDAL is best option for hi res. music streaming.
No problems in 3 years.
Aussie Michael
Melbourne, AU
Posts 3,730
I use an iPad now
Millemissen
Flensborg, Denmark
Posts 14,680
As you probably know, I use - and have used for a while - an iPad (Mini) too.....with a vertical stand.
Great stand there - where did you get that?
It seems to have just the right angle for a desktop.
Duels
England
Posts 2,553
Duels replied on Fri, Apr 26 2019 6:47 PM
Millemissen:
Same question from me.......
Aussie Michael
Melbourne, AU
Posts 3,730
I swear I’m going crazy, this is now the second time on this thread where i have posted something good lol and it didn’t appear. So frustrating
Yes, the stand is a Heckler Design.
It is also sold in Aussie Land under a different brand in the national chain of shops called Officeworks.
It is more stable and effective for multi room than my encore ever was, although the encore looks way better of course. But functionality , it’s on a different level.
I had 5 iPads, so made sense to make one of them a music centre for deezer and my collection.
With the rain fall I think the product is, i just used permanent marker on the front facing screws to blend them in to the black surround.
Duels
England
Posts 2,553
Duels replied on Sat, Apr 27 2019 9:37 AM
Thanks Michael and marexy
I’m going to dedicate an iPad just to music now I’m using a Core. Need to buy a new one so the only question is which one to keep for general use and which one for music. Now that really is a first world problem.
Aussie Michael
Melbourne, AU
Posts 3,730
Duels:
And the core is hi Rez so that’s good
Millemissen
Flensborg, Denmark
Posts 14,680
Duels:
Now that is an easy one - the old for music and the new one for general use.
By the way: there have always been 2 main categories of ‘users’ when it comes to controlling music with a mobile device.
Firstly there are those, who seem to have their (i)Phones glued to their hands.....ready for action all the time, 24/7.
Secondly there are those who wants to seperate work, talking on a phone, using social media/mail from their listening to music at home.
Those were the guys that B&O tried to serve with the concept of the BS Moment!
However, when this does not work (it is EOL anyway) or the way the Moment works was not enough, a seperate tablet/iPad (Mini) can be the solution of that problem.
Personally I have had an (older) iPad Mini dedicated for the Bang & Olufsen app and a few other app for my music setup AND my iPad, that I use for general things (pretty much everything), for quite a while now. The app is of course complemented with the physical Beo remote.
I can only recommend dedicating an iPad for the B&O setup to everybody..........unless he/she happens to be in the first category.
Paul cheacker
Spain
Posts 130
It could be the battery in your case which will be cheaper. In my case they checked it and said due to the model i had it had to be replaced
Duels
England
Posts 2,553
Duels replied on Mon, Apr 29 2019 8:23 AM
Millemissen:
You are right of course MM, and that is what I will do..........
seethroughyou
UK
Posts 999
Here I am thinking of buying a new Beosound Moment at a good price with a 2 year warranty, after the software has finally matured and stabilised yet everyone else is moving to a Core....someone out there must be enjoying the Moment and preferring it to an iPad in their hands...?
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Page 1 of 3 (88 items) 1 2 3 Next > | RSS
DigiCert Secured Site Seal
