Hi, I bought a beo sound moment off of ebay in January so decided to buy the wall stand. whilst installing the stand and putting the cables inside the wall to make a clean look, the beo sound moment was unplugged for two days. after replugging it in now the screen is just blank. its been on charge over night and still nothing. is this correct what I've been reading that this is a known issue and it will need to be repaired. to me thats incredible i have never had a product in my life before whereby being off charge it needs to be repaired. if this is so, how much will this cost. its very nearly turned me off of b and o and on to sonos.
if anyone knows how to fix this, or how much it costs can you please advise me. thanks
Current b and o Products
beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort,
I have read a lot on the forums about this issue, I've tired resting it using the small hole in the the top. Nothing happens, I ve reset the moment and the jukebox nothing happed. I can not understand why a brand of this quality when the battery discharges you can't get it to recharge. I have never in my life experienced a product from any manufacturer that has this issue. Like I said I've searched the forums I can't find a solution so if anyone has one id appreciate it. however if this does prove to be a repair issue and I have to pay it will be the very last product from B and O i ever purchase.
My moment has discharged fully on multiple occasions and I’ve never had this issue. It would seem a repair is needed to me.
Beovision 10, Beoplay V1, Beolab 17, Beolab 9, Beolab 4, Beosound 2, Beosound Moment x 2, Beoplay M3, Beogram 1700
Here is a thread with similar problem.
He had to repair it. Seamed the seller sold you a lemon unfortunately.
I have sent a message to the AMGRACE the bang and olufsen shop in leamington Spa where I bought it from, as I do not feel this is fair. Now I see the reason B and O discontinued this product seems like a lot of people have had the same issue. Lets see what the shop says. However if this becomes a repair issue I have to pay for then after being a B and O shopper I will sell my products and move to another brand.
However Im going to see what they say first.
Hiort:Here is a thread with similar problem. He had to repair it. Seamed the seller sold you a lemon unfortunately.
Do you mean take it off the charger again leave it for a day then put it back on charge.
Paul cheacker:Do you mean take it off the charger again leave it for a day then put it back on charge. Current b and o Products beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
Well I basically did everything people said and still dead no response what so ever. So I decided to contact the Bang and Olufsen shop I brought it from which was B and O in Leamington Spar. Well the response just shows me what B and O think about customer service. The reply is below, and although I understand that its going to need to be repaired, this item was brought two months ago from a B and O dealer and although second hand not even an offer towards some of the costs. This has taught me a valuable lesson, I will have to get the Beosound moment jukebox fixed but it will be the last item I ever buy from this brand and I have been buying things for the last 15 years.
Below is the B and O shop response. Great service.
Sorry to hear that the Jukebox isn't charging. It's worth checking that the contact between the two components is good. In some cases performing a reset on the Jukebox might work but the likelihood is that the internal battery on the Jukebox requires replacing,With BeoSound Moment, the servicing proceedure is to take the system (I would suggest the Soundheart as well) to your dealer of choice. They should send the combination to the Bang & Olufsen designated Service Centre based in Northern Germany. As it would be a chargeable repair you may be asked for a fee upfront to cover the cost of providing a quotation for you.The process usually takes around 2-3 weeks.In Valencia, here is the link to the dealer in the city:https://stores.bang-olufsen.com/en/spain/valencia/gran-via-marques-del-turia-75Hope that this info helps.
Kind Regards Steve Jones | Sales Executive BANG & OLUFSEN Bang & Olufsen of Leamington Spa78 Regent Street | Leamington Spa | Warwickshire | CV32 4NS | UKPhone: 01926 881500 | Mobile: +44 7940 263256| WhatsappE-mail: leamington@amgrace.co.uk
Paul cheacker: Hi, I bought a beo sound moment off of ebay
That might be the last item I would buy off ebay!
I did want to buy Moment
and regarding all problems ..i think not ..and it's not possible to repair it on component level ..as many new B&O items.
As BL4 power amp PCB.. hey 130€ for 5x7cm electronic board ..are you MAD..wt..f.
Hi Millemissen you should of read my last enter it was bought on ebay from B and O Leamington Spar shop, a lot of B and O shops sell products on ebay. So yeah Im right to be angry and I have rights under uk law. which I have wrote to the shop about and are awaiting an answer.
I bought it in January it is 3 years old and it was not mentioned to me at ll or in the listing who it was being sold on behalf of.
Paul cheacker: Hi Millemissen you should of read my last enter it was bought on ebay from B and O Leamington Spar shop, a lot of B and O shops sell products on ebay. So yeah Im right to be angry and I have rights under uk law. which I have wrote to the shop about and are awaiting an answer.
Ok - then!
But as Ralf wrote, ‘If you bought it from a shop you should have some warranty. Even for used stuff. Minimum 6 months.’
Anyway Ive taken it back to a B and O dealer in Valencia Spain where I live, lets see the outcome. Depending on this, can someone advise me if there is a set of headphones that can be linked to the moment to wirelessly listen to music
Hate to be the cranky realist here but the moment is the worst product B&O has ever made.
The moment can't do anything an iPad with a cheap NAS/Sonos can't do, for 1/10th the cost. I'd suggest getting your money back if you can.
BeoLab 18's. Beolab 3's. A8. A9. A2. H7.
Paul cheacker:Well I guess in life we all have our own personal opinons, I myself like the moment alot. So my question is there away to connect wireless headphones with the moment if so does anyone know which ones?
I would think being functional and reliable would be conditions for liking it alot, or did I miss a post?
Paul cheacker:So my question is there away to connect wireless headphones with the moment if so does anyone know which ones?
Unfortunately, my Moment just experienced exactly the same issue. That is, my Moment was working fine when I unplugged the power cable of the Soundheart with the Jukebox still on the Soundheart. After a couple of weeks with the Soundheart being without power, I went to resetup the Moment. The Jukebox was unresponsive, but I assumed it was discharged so I plugged in the power cable of the Soundheart. After days of trying to charge the Jukebox, the Jukebox would not come back to life (although the Soundheart appears to be functioning properly). That is, the screen remains dark and the Soundheart (as far as I can tell) does not see the Jukebox. I believe I’m a month or so out of the 3 year warranty, so it looks like I’ll have to spend $800 to replace the Jukebox.
Severed_Hand_of_Skywalker: Hate to be the cranky realist here but the moment is the worst product B&O has ever made. The moment can't do anything an iPad with a cheap NAS/Sonos can't do, for 1/10th the cost. I'd suggest getting your money back if you can.
The encore tops the list i think
So sorry for all you with no luck on BSM.
I did want to purchase BSM some time ago
As you probably know, I use - and have used for a while - an iPad (Mini) too.....with a vertical stand.
Great stand there - where did you get that?
It seems to have just the right angle for a desktop.
Millemissen: Great stand there - where did you get that?
something like that ?
http://www.macmall.com/p/Heckler-Design-Computer,-Tablet-And-Printer-Stands/product~dpno~40456040~pdp.bbfdhije
https://www.videoconferencegear.com/zoom-room-ipad-mini-stand-console-by-heckler-design/
Duels:Thanks Michael and marexy I’m going to dedicate an iPad just to music now I’m using a Core. Need to buy a new one so the only question is which one to keep for general use and which one for music. Now that really is a first world problem.
Duels: I’m going to dedicate an iPad just to music now I’m using a Core. Need to buy a new one so the only question is which one to keep for general use and which one for music. Now that really is a first world problem.
Now that is an easy one - the old for music and the new one for general use.
By the way: there have always been 2 main categories of ‘users’ when it comes to controlling music with a mobile device.
Firstly there are those, who seem to have their (i)Phones glued to their hands.....ready for action all the time, 24/7.
Secondly there are those who wants to seperate work, talking on a phone, using social media/mail from their listening to music at home.
Those were the guys that B&O tried to serve with the concept of the BS Moment!
However, when this does not work (it is EOL anyway) or the way the Moment works was not enough, a seperate tablet/iPad (Mini) can be the solution of that problem.
Personally I have had an (older) iPad Mini dedicated for the Bang & Olufsen app and a few other app for my music setup AND my iPad, that I use for general things (pretty much everything), for quite a while now. The app is of course complemented with the physical Beo remote.
I can only recommend dedicating an iPad for the B&O setup to everybody..........unless he/she happens to be in the first category.
Millemissen:Now that is an easy one - the old for music and the new one for general use.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
