'dark grey' - just like the BL12's coming with the BV12 NG.
!!!Keep your BV11-46!!!
It is an excellent tv - unless you really want/need something bigger
N.B. Maybe we should stop calling the BV's 'tv's' - they are in fact much much more than a tv.
changing speaker covers
this alone will no doubt save bno
Hay all question from me abut the beosystem 4.
Will the BS 4 distribute SD to older beovisions?
the BS 3 can send SD to my bedroom beovision 3.
Eclipse 65V1-32Beosound M5Essence MK2BLI
seanklemis:Will the BS 4 distribute SD to older beovisions?the BS 3 can send SD to my bedroom beovision 3.
Beoworld app with direct photo upload and emoticons.
I did not react to that question, because I was not sure, if if was meant as 'some kind of comment', or if it actually was a question.
This subject has been disquessed in several different versions on the forum.
With the new platform - starting with the BV11/V1 - there is no SD videodistribution anymore.
This a result of the end of analog signals.
It is really not worth lookig at at a bigger screen, and there would be no way to control it since this was/is done via ML.
A few people are going to miss it - if you (Seanie) are one of those, just, stick to your BSys3...
...at least as long as your BV3 is still working.
Alternatively just have a Sky HD box with the second tv as well.
If I look at what one gains with the new BSys4, I just can say: this is the future.
Greetings Millemissen
PhilLondon: I doubt. B&O is moving away from SD distribution using a coax cable because it looks bad on larger screens.
I got around this with a simple powered HDMI splitter and a PUC. Works a treat. I can simultaneously display the same channel on both the BV11-46 in the sitting room and the BV10-32 in the kitchen, without the delay you had with masterlink. You get a HD picture and both TVs are controllable via the Beo4.
I can also mirror the content from the NAS drive to both TVs and an Apple TV is connected to both.
Job done. Who needs masterlink? :)
moxxey: Job done. Who needs masterlink? :)
No one. That's why it's dead, but you've obviously figured that out already and hopefully others will follow
Old trick!
Works good as long as the distance is resonable.
Agree, I use the same trick with up to 15M HDMI cables, works perfectly.
However, I still use the ML for sound distribution of i.e. Radio or CD to the kitchen or to our outdoor speakers. And I do think that this still will be a core in the future B&O integration just using NL instead.
moxxey: PhilLondon: I doubt. B&O is moving away from SD distribution using a coax cable because it looks bad on larger screens. I got around this with a simple powered HDMI splitter and a PUC. Works a treat. I can simultaneously display the same channel on both the BV11-46 in the sitting room and the BV10-32 in the kitchen, without the delay you had with masterlink. You get a HD picture and both TVs are controllable via the Beo4. I can also mirror the content from the NAS drive to both TVs and an Apple TV is connected to both. Job done. Who needs masterlink? :)
Hay that method sounds like a great idea and when when I upgrade and also upgrade the bedroom tv.
do you have both IR blasters on the one sky box?
Millemissen: Old trick! Works good as long as the distance is resonable.
Hardly a 'trick'. More of a 'solution'. Works better than masterlink - no silly audio delay, proper HD and everything controllable. As for distance, you can get a good 15 metres or more and get a far better picture than via masterlink's analogue! There aren't many people, in 2013, wanting to connect one TV to another, on different floors!
Seanie_230: do you have both IR blasters on the one sky box?
Yes, works fine! You can, of course, control via one Beo4, but I've chosen to have two separate Beo4's for each TV, both controlling the Sky box.
Masterlink didn't give me a good enough picture on my old BV28, was always disappointed. Blu-rays were very jerky, too. Plus audio delay if both TVs were on at the same time, which often happens.
The TVs are a few metres away, the HDMI cable simply replaced the old analogue RF cabling.
I have become quite disenchanted with my RF modulator solution - seemed workable a year or so ago, but something some where has deteriorated and I can't be bothered to track it done.
Your solution seems good enough - what HDMI splitter did you get ?
And I presume the PUC cable is just super long ? (i.e. not amplifier along the way)
BeoNut since '75
Well I think B&O should start looking into making loudspeakers like this. Cheap to built but cheerful to look at.
http://www.avantgarde-acoustic.de/zero1/_en/zero-einfach.html
I believe that form should always correspond with function so as to easily inform. I think the upper range of B&O equipments should be built with more luxurious materials whereas the lesser performing ones should be built with cheaper materials but no less chic.
PS. I think Avantgarde might have taken my idea for this product. Because I did shoot them an email regarding an idea for the exact same product last November and hey this active loudspeaker is launched in May. ( I just checked my email outbox to confirm this)
So why would that high-end audio brand take my idea and B&O seems to never respond?
You don't really mean that, do you
They may sound good, but...
..,if I had to have them at my place, I would certainly hang a curtain in front them - pfui!
And before you stick your nose to high in the sky (sorry moderators, I had to write this), please concider, that the development of a loudspeaker/loudspeakerconcept takes much longer than from 'last november till may this year'.
I doubt that your email had any influence on the Avangarde product - just me 2 cents.
And by the way - let os stick to the theme of the original poster: "New products in the next 6-12 month". He asked for facts, not fiction.
Grrr! Millemissen
wonderfulelectric: So why would that high-end audio brand take my idea and B&O seems to never respond?
elephant: Your solution seems good enough - what HDMI splitter did you get ?
Good question. Was recommended by B&O. It's this one: http://www.amazon.co.uk/gp/product/B001D9P1OW/ref=oh_details_o02_s00_i04?ie=UTF8&psc=1
elephant: And I presume the PUC cable is just super long ? (i.e. not amplifier along the way)
Yeah, quite a few metres. I think that was there before, as the TV needs to handle the remote control (as I always had a second Beo4, solely for the old BV8). Now I have a BV10-32 on the wall, where the BV8-26 used to be located) and that simply uses the existing PUC and the hdmi replaces the masterlink.
wow..... just wow....
Ah, you know... A little B&O here, a little there
wonderfulelectric: Well I think B&O should start looking into making loudspeakers like this. Cheap to built but cheerful to look at.
Cheap to build: probablyCheerful to look at: seriously???
Back to the topic: really wondering what the next music system will be like... With regard to TVs... BV7 probably going EOL... So maybe a replacement? Or is Stuer going for BeoPlay 1 / BV 11 / BV4 ?
Those speakers look like traffic lights made of melted ice cream.
TripEnglish: Those speakers look like traffic lights made of melted ice cream.
Too long to list....
kuyttendaele: Back to the topic: really wondering what the next music system will be like... With regard to TVs... BV7 probably going EOL... So maybe a replacement? Or is Stuer going for BeoPlay 1 / BV 11 / BV4 ?
@Karel: yes, this is the big question - what can they do after the BS/BM5-combo? The BS5e wasn't the hit it could have been.
This thread was a bit difficult to read/follow, so I am sorry if this info was already posted earlier: The BV12NG / BS4 is about to get released, and the biggest news seem to be the topaz grey color and the price reduction compared to the BV12/BS3 combo. The new topaz grey color will please those that find the current shiny edition of the BL12-3/-2 looking a bit like those mirrors found at the Tivoli. The stand is close to identical to the 7-55 floor stand, but the back panel looks very good – as it appears now, you will have to order the BV12 as a wall or floor edition and you cannot (easily) convert between floor/wall later on. Next year they will release the floor stand with mechanical links: it will move itself away from the wall as the TV turns. Also, they have another TV coming with a speaker that sits below the screen and will rotate out of view when turned off.
On the audio side they have plenty of new products lined up for the next year, and the “new” BL8k will create some traffic on this site with its ALT lens and the wood-panels-in-a-fan-shape at the front (replacing the current cloth design).
Not sure when the top-of-the-line speaker, as mentioned by Peter, will be released – but it may be a long way from production still. It is massive (prototype) and can move a lot of air, so you will need a house with friendly or no neighbors to take full advantage of them. Also, on the audio side, is the new Playmaker – finally it will lose its not-so-exclusive-look and be replaced with new hardware in a much more classy wrapping. I guess the new technology that they will release on the speaker side making them wireless (still need the power cord) is of more concern to interior designers than beoworlders.
Roger
"....The BV12NG / BS4 is about to get released, and the biggest news seem to be the topaz grey color and the price reduction compared to the BV12/BS3 combo...."
I don't agree on that - the biggest news definitely is the BSys4!
Anyway, thanks a lot for all other information, appreciate that - I am eager to see and hear what is coming.
Yes, you may be right, Millemissen - I was just a bit disappointed by the BS4, I guess I was hoping for a step change compared to the BS3 as a superb video engine and not just the V1/BV11 video card with more features. But we will have to study it closely when we get to play with it.
Roger: On the audio side they have plenty of new products lined up for the next year, and the “new” BL8k will create some traffic on this site with its ALT lens and the wood-panels-in-a-fan-shape at the front (replacing the current cloth design).
"wood-panels-in-a-fan-shape" surely sounds interesting. Can anyone elaborate more on this design and what to expect?
/C
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Roger:Also, on the audio side, is the new Playmaker – finally it will lose its not-so-exclusive-look and be replaced with new hardware in a much more classy wrapping.
I hope they give it some functionality too !
Such as acting as a "network extender", a function that the Airport Express has, and which would be convenient if packaged as part of the PlayMaker.
I don't think so - Bang & Olufsen is an audio/video company.
B&O has always recommended the use of a dedicated router for the Network Link, so why should they offer a network extender?
I suppose a new 'packaging' and NL capacity (just my guess and hope).
Roger: Yes, you may be right, Millemissen - I was just a bit disappointed by the BS4, I guess I was hoping for a step change compared to the BS3 as a superb video engine and not just the V1/BV11 video card with more features. But we will have to study it closely when we get to play with it. Roger
Hi Roger,
it seems that you already have 'seen' it or - that you have attended the video courses a couple of days ago.
I haven't! And will have to wait a couple of weeks for it.
But I know that the 'Cinema option' will come later - end of this year - with a software update.
So more functionallity might come the same way - this video engine is strong.
I wonder what you are missing though?
Two features described in the 'Launch Package seems interesting:
"Network Link connectivity introducing synchronised sound distribution
Two-way tablet control via BeoRemote App* operation "
I wonder if there is something new about the "synchoniced sound distribution"?
Maybe the BeoRemote app has some new functionallity with the arrival of the BSys4?
Roger:I guess the new technology that they will release on the speaker side making them wireless (still need the power cord) is of more concern to interior designers than beoworlders.
I would disagree - I think high quality, wireless active speakers could be a very big deal for B&O, the key here would be a reliable wireless connection performance. They would convert any wireless audio source into a quality B&O audio "system" which could easily lead to future B&O purchases. People may make the leap from docks such as the Bose, B&W and even the A8 to a "proper" stereo speaker setup.
Ban boring signatures!
I would like to know more about "the new technology that they will release on the speaker side making them wireless", before judging if that might be 'a very big deal' for B&O or not.
Millemissen: I would like to know more about "the new technology that they will release on the speaker side making them wireless", before judging if that might be 'a very big deal' for B&O or not. MM
Fair point, if it's an additional component the size of a shoebox that sits next to each speaker then "a very big deal" is clearly wrong. If it's internal to the speaker housing then I stand by what I said.
Wireless in B&O term: loose 1 of the 2 wires... We'll still need a power cable
That is one step ahead. Next step will be a built-in battery with enough power for 20 years
Very much a big deal if they perform like the BeoLit 12 and Playmaker. I don't think I've ever had a worse-performing wifi device. The Playmaker provides superb audio, but just cuts out way too much to be used seriously. Nothing like the performance of an Airport Express for wifi stability. I have AE's many rooms away from the router that perform better than the Playmaker.
Bang & Olufsen is a member of WISA - http://www.wisaassociation.org/
If some of this is realized there certainly will be no 'shoebox' sitting next to a loudspeaker.
moxxey:Very much a big deal if they perform like the BeoLit 12 and Playmaker. I don't think I've ever had a worse-performing wifi device. The Playmaker provides superb audio, but just cuts out way too much to be used seriously. Nothing like the performance of an Airport Express for wifi stability. I have AE's many rooms away from the router that perform better than the Playmaker.
MartinW: moxxey: Very much a big deal if they perform like the BeoLit 12 and Playmaker. I don't think I've ever had a worse-performing wifi device. The Playmaker provides superb audio, but just cuts out way too much to be used seriously. Nothing like the performance of an Airport Express for wifi stability. I have AE's many rooms away from the router that perform better than the Playmaker. Very valid concerns Moxxey, the good news is that this new technology (not sure if new means new to market or new to B&O) isn't wifi, doesn't require a router, and it lives in 5Ghz land so hopefully something good to look forward to! :)
Thanks Martin for the link - I would be worried that they will turn out to be high quality islands like my Wireless 1s !
From reading the site it seems targeted at surround sound set ups, and not wireless through out the house, i.e. no obvious references to how one would handle multiple rooms / zones ...
WISA™ KEY ATTRIBUTES Some of the key attributes of WiSA technology include: 24-bit uncompressed audio for true audiophile sound – HD quality, perceptibly 50% better than CD audio Sample rate that matches the content: 32, 44.1, 48, and 96k samples/second Rapid error detection and recovery for uninterrupted listening enjoyment 5 ms fixed latency – perfect lip synch and immediate game response Under 160ns speaker-to-speaker delay – theatre quality surround experience Amplifiers and speakers matched and balanced as a unit – same quality sound in all directions
Elephanth wrote : "Thanks Martin for the link".
If you mean the WISA link - that link was in my post
Anyway, the WISA thing is meant for setting up a surround system completely wireless - of cource power is still required as by any active speaker system.
It is not meant for multiroom connections.
I once saw a video from the makers (can't find the link) of WISA - they mentioned Bang & Olufsen as one of the pioneers in the history of active speakers.
As always with wireless you need a sender, which could be built into an AV-receiver, a blurayplayer or a tv - in fact a BV with the surround processor and the preamp already built in would be predestined for that. The receivers that have to be built in to the speakers are quite small.
See the WISA site and Youtube it (search for WISA wireless) for more details.
On the other hand, I doubt that this will be realized from B&O in short - but might be something coming.
Probably the mentioned and expected wireless speaker will be less complicated, nothing fancy - just my guess.
The implantation of the WISA thing requires a lot of devellopment - and B&O is a small company.
A small company with a very broad portfolio, that must be maintained - as you know every one of us demands software updates at the very moment a problem has turned up..
B&O must present some new products in the next months - maybe they won't all be as 'breathtaking' as BeoWorlders expect it - but they surely will put Bang & Olufsen on the 'home entertainment' map.
If we will see the things that Roger mentioned coming soon, we should be very pleased - even if 'our product' is not amongst it.
Millemissen: Elephanth wrote : "Thanks Martin for the link". If you mean the WISA link - that link was in my post
Apologies - you are correct it was your link that Martin was commenting on .....
"I must not post when I am tired" "I must not post when I am tired" "I must not post when I am tired"
