BeoLiving news & support from Khimo!
This post has 635 Replies | 20 Followers
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Nov 15 2021 8:45 AM
For those having the Clock programmed in the Halo, having the months the other way:
  if month == 1 then month="Jan"
    elseif month==2 then month="Feb"
    elseif month==3 then month="Mar"
    elseif month==4 then month="Apr"
    elseif month==5 then month="May"
    elseif month==6 then month="Jun"
    elseif month==7 then month="Jul"
    elseif month==8 then month="Aug"
    elseif month==9 then month="Sep"
    elseif month==10 then month="Okt"
    elseif month==11 then month="Nov"
    else month="Dec"
  end
Copy and put it before the first "engine.fire"
TWG
Posts 1,672
TWG replied on Mon, Nov 15 2021 2:39 PM
to have it verified:
To control e.g. a Beosound 9000 with a HALO remote I need both, NL / ML Converter AND BLI or BLGW?
Will it work with NL / ML Converter AND the older MLGW?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Nov 15 2021 2:54 PM
TWG:
You need a NL/ML converter AND a BLI.
BLGW won't do nor does the MLGW.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Wed, Nov 17 2021 5:30 AM
Carolpa:
true, but I (mis)read your post that way.
But maybe just a concept for Khimo to think about:
BLI settings trigger:
Event: Halo button,
Command: IF icon (or other trigger) = lights THEN
Lua program to dim "lights" + after 10s change the icon to "rgb color"
ELSE Lua program to change colors + after 10s change the icon to "lights"
Would this work?
this concept works. I just made an interactive button to toggle between the 6 CD’s of the BS9000.
So use the same button to go to one of the six CD’s.
TWG
Posts 1,672
TWG replied on Wed, Nov 17 2021 1:22 PM
Carolpa:
TWG:
Thank you.
TWG
Posts 1,672
double post, please delete.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Wed, Nov 17 2021 7:31 PM
BLI program to use one button on the Halo remote to toggle between CD1 to CD6 of a BLC connected BS9000.
-. Beolink converter NL/ML setup as ASlave (BS9000 is sole ML device connected).
-. CD is set to be visible in NL .
Start with, goto “Virtual Resources”:
Define a “Virtual Resource” Integer, named as “Number”. Place this resource in the area/zone of your Halo remote.
Goto “Interfaces”, “B&0 Halo remotes”:
Choose your Halo and program a Halo button as shown below.
Goto “Macros”:
Make an “Event” : Halo_Area/Halo_Zone/Halo remote/Your_Halo/
BUTTON_RELEASED?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx
with the correct button
Copy the lines below in the field “Execute the following lua code”
function(event, engine)
  local numbr_query = engine.query("Halo_Area/Halo_Zone/VARIABLE/Number")
  local numbr = numbr_query[1].get_number("VALUE")
  if numbr==nil then
    numbr=0
    elseif numbr>5 then
      numbr=0
  end
  if numbr==0 then
    cdnumber=1
    engine.fire("Halo_Area/Halo_Zone/Number/SET?VALUE="..tostring(cdnumber))
  elseif numbr==1 then
    cdnumber=2
  elseif numbr==2 then
    cdnumber=3
  elseif numbr==3 then
    cdnumber=4
  elseif numbr==4 then
    cdnumber=5
  else
    cdnumber=6
    engine.fire("Halo_Area/Halo_Zone/VARIABLE/Number/SET?VALUE=0")
  end
--set text Halo button
  engine.fire("Halo_Area/Halo_Zone//Halo remote/your_Beoremote_ Halo_name/SET_TEXT?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx&TEXT=".."cd"..tostring(cdnumber))
--play cd1-6 on all av renderers in this aera / zone /
  engine.fire("Halo_Area/Halo_Zone/AV renderer/*/Select source?Connector=&Origin=<BL_NL/ML_converter_IDnumber>&Source Type=CD")
--select cd number
  engine.fire("$Area/$Zone/AV renderer/<Name_of_ BL_NL/ML_converter >/Send digit?Digit="..tostring(cdnumber))
--set wheel to number of cd
  engine.fire("Halo_area/Halo_zone/Halo remote/your_Beoremote_ Halo_name/SET_WHEEL_VALUE?BUTTON=497f6eca-6276-4993-bfeb-000000810363&VALUE="..tostring(math.floor(cdnumber*100/6)))
end
  • Set all Halo_Area in the code to your settings correct.
  • Set all Halo_Zone in the code to your settings correct.
  • Set your_Beoremote_Halo_name
  • Put the correct Halo button ID number in the code to your settings.
  • Place the correct BeolinkNL/ML converter IDnumber in the code (= Address on page “Resources” of the Beolink NL/ML converter)
  • Put the correct name of the Beolink NL/ML converter in the code (see same page)
added remarks to explain + setting of the button wheel
Pictures of the result on the next post
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Wed, Nov 17 2021 7:52 PM
A loop, every time you release the button the next cd is chosen. After cd6 it restarts with cd1, etc.
note: where it start depends on the latest value set in the program
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Nov 20 2021 2:04 PM
a question to the Khimo team / forum members:
I want to use among other, for example _WindDirection or _Cloudiness of the Open Weather source.
I get stuck by the Error about the type (monitored in Tools/Monitor) . If you look at the Error it says for example that I must use "double" instead of "integer".
So I'm using "double". But then it get stuck because of the NIL "value".
And yes, if one looks at Open Weather to the values for the city set, then some of them should not be / are not NIL (for the moment it doesn't rain, the expectation are, there will come no rain the next three hours, so one could expect the _RainLevel3Hrs has the value NIL. But others should have a value.....).
Another remark: the BLI Github manual doesn't give the possibility of "event get_double" or the engine query get_double"?
Please advice.
To be clear, not all Resource States do have these issues. For example _Temperature just works fine.
SirPump
Posts 14
SirPump replied on Mon, Nov 22 2021 1:54 PM
Hi Khimo, Is the Honeywell Evohome system (still) supported?
Does anyone have it integrated in their BLI?
SirPump
Posts 14
Khimo Support
Posts 181
Hi Carolpa, you actually pinpointed an issue we had with numbers with a decimal point and the get_number function (lua has no integer type, the only numeric type is the "number" type which represents real (double-precision floating-point) numbers). We have already fixed it and this week it should be working. Extra tip: remember you can find the weather resource's states in the Resource States window (to see if they are empty/nil).
SirPump, regarding HoneyWell, it isn't supported at the moment, but we have been receiving many requests for it and I believe there may be news on this front soon ;)
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Nov 28 2021 2:49 PM
Just for the  fun. Another example of using one Button double. This time Weather and Clock:
Weather shows: temperature [Celcius], rain [mm] or snow [cm] and winddirection on the Wheel of the button (Nord=50%, West=25%, East=75%, etc.).
Clock: time (also on the Button Wheel) and date.
  -- make in Resource a Variable "Weer" type Boolean
  local clockorweather=engine.query("YourArea/yourZone/VARIABLE/Weer")
  local cl_we = clockorweather[1].get_boolean("VALUE")
  if cl_we==false then
    cl_we=true
    engine.fire("YourArea/yourZone/VARIABLE/Weer/SET?VALUE="..tostring(cl_we))
local clock = engine.query("*/*/SYSTEM/Clock")[1]
day = clock.get_number("day")
month = clock.get_number("month")
hour = clock.get_number("hour")
minute = clock.get_number("minute")
if minute < 10 then
minute = "0" .. tostring(minute):gsub("!","")
  else
    minute = tostring(minute):gsub("!","")
  end
    if month == 1 then mnd="Jan"
      elseif month==2 then mnd="Feb"
      elseif month==3 then mnd="Mar"
      elseif month==4 then mnd="Apr"
      elseif month==5 then mnd="May"
      elseif month==6 then mnd="Jun"
      elseif month==7 then mnd="Jul"
      elseif month==8 then mnd="Aug"
      elseif month==9 then mnd="Sep"
      elseif month==10 then mnd="Okt"
      elseif month==11 then mnd="Nov"
      else mnd="Dec"
    end
    hour = tostring(hour):gsub("!","")
    engine.fire("YourArea/yourZone/Halo remote/YourBeoremoteHalo/SET_TEXT?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx&TEXT="..tostring(hour)..":"..minute)
    engine.fire("YourArea/yourZone/Halo remote/YourBeoremoteHalo/SET_TITLE?BUTTON=497f6eca-6276-4993-bfeb-000000810337&TITLE=Clock")
    engine.fire("YourArea/yourZone/Halo remote/YourBeoremoteHalo/SET_SUBTITLE?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx&SUBTITLE="..tostring(day).."-"..mnd)
    engine.fire("YourArea/yourZone/Halo remote/YourBeoremoteHalo/SET_WHEEL_VALUE?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx&VALUE="..tostring(math.floor(hour*100/24)))
  else
  cl_we=false
    weather_query = engine.query("YourArea/yourZone/_CURRENT_WEATHER/Oldenzaal")
    local rain = weather_query[1].get_boolean("_Rain")
    local snow = weather_query[1].get_boolean("_Snow")
    local temperature = weather_query[1].get_celsius("_Temperature")
    local rainlevel = weather_query[1].get_number("_RainLevel3Hrs")
    local snowlevel=weather_query[1].get_number("_SnowLevel3Hrs")
    local winddirection = weather_query[1].get_number("_WindDirection")
    local subtitle = "Rain"
    local neerslag = 0
    local sub= "x"
    local dim=" mm "
    if snowlevel>0 then
      neerslag = snowlevel/10
      subtitle = "Snow"
      dim=" cm "
    elseif rainlevel>0 then
      neerslag = rainlevel
      subtitle = "Rain"
      dim=" mm "
    end
    sub=tostring(neerslag)..tostring(dim)..tostring(subtitle)
    if winddirection<=180 then
      winddirection=winddirection+180
    else
      winddirection =winddirection - 180
    end
    engine.fire("YourArea/yourZone/Halo remote/YourBeoremoteHalo/SET_TEXT?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx&TEXT="..tostring(temperature).."C")
    engine.fire("YourArea/yourZone/Halo remote/YourBeoremoteHalo/SET_TITLE?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx&TITLE=Weather")
    engine.fire("YourArea/yourZone/Halo remote/YourBeoremoteHalo/SET_SUBTITLE?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx&SUBTITLE="..sub)
    engine.fire("YourArea/yourZone/Halo remote/YourBeoremoteHalo/SET_WHEEL_VALUE?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx&VALUE="..tostring(math.floor((winddirection)*100/360)))
  end
end
Tassos
Athens
Posts 323
Tassos replied on Mon, Nov 29 2021 10:45 AM
Chapeau!!!! Great Macro Carolpa! I named it after its creator...."Carolpa Halo Macro" Yes - thumbs up
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Nov 29 2021 12:16 PM
Big Smile
Seanie_230
UK
Posts 2,278
@Khimo team
Any news on the Tado intergration?
Cheers
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Khimo Support
Posts 181
Seanie_230:
@Khimo team
Cheers
Hi Seanie,
Sadly we have not heard back from any of the different channels through which we tried to contact Tado, so we'll have to wait for them to publish an official API.
There's a Christmas present to wish for!
SirPump
Posts 14
SirPump replied on Mon, Dec 6 2021 10:10 AM
Hi Khimo, great first feedback on the EvoHome integration. Patience is a virtue i know :)
Would it be possible to share a preliminary timeline on the integration?
ebnrob
UK
Posts 174
ebnrob replied on Mon, Dec 6 2021 11:16 AM
Khimo Support:
Hi Khimo, I also use Evohome (EU) so having this on my BLGW would be fantastic, so keeping my fingers crossed it'll be available on the older BLGW!
Khimo Support
Posts 181
Hi SirPump and ebnrob,
I have some good news and some bad news to share with you guys: The good is that I can confirm that the Honeywell driver will be out this month! The bad (for ebnrob) is that because of the tools we are using for development, it will not be available on the BLGW :(
SirPump
Posts 14
SirPump replied on Mon, Dec 6 2021 3:39 PM
Hi Khime, That is a wonderful outlook for the BLI out there. With thanks.
Frederik
Belgium
Posts 94
With the BLI, is it possible to change speaker settings such as listening mode, loudness etc? Idea would be to have an automation to have specific settings for example depending on time of the day.
CTR
Denmark
Posts 25
CTR replied on Tue, Dec 7 2021 9:53 AM
You can easy change Speaker groups due to time of day, or Or what other inputs you want to use :)
Frederik
Belgium
Posts 94
Frederik replied on Tue, Dec 7 2021 10:08 AM
CTR:
But can you change sound settings of an individual speaker. For example, in the morning I want to listen to the news from 7-8 am on an A9 and have the listening mode set to "Speech" and loudness turned off. At other times, when listening to music I want to have it at "Optimal" and loudness on.
Frederik
Belgium
Posts 94
Frederik replied on Fri, Dec 10 2021 2:22 PM
To answer my own question, I managed to do this with the Shortcuts app on iOS, so it should be possible via BLI as well I guess.
To turn of the Loudness for example, you make a PUT request to http://SPEAKER_IP:8080/BeoZone/Zone/Sound/Adjustment/ with the following content:
{"adjustment":{"treble":0,"bass":0,"loudness":false}}
I could not find a description of the API, but you can simply do the action in the B&O app and catch and replicate the request. For beosonic you can do the same, but the request is a bit more complicated.
Frederik
Belgium
Posts 94
Frederik replied on Fri, Dec 10 2021 2:25 PM
For Mozart products the API is different, the URL would be http://SPEAKR_IP/api/v1/sound/settings/adjustments/loudness and the content {"value":false}
CTR
Denmark
Posts 25
CTR replied on Sat, Dec 11 2021 9:40 PM
Hey Khimo.
It could be cool, if you could use the BLI to choose which product Beoremote Halo is associated with.
So e.g. at 8am it controls my Beoplay M5 and from 6pm, it controls my Beovision. Is this possible?
CTR
Denmark
Posts 25
Hey Khimo.
Khimo Support
Posts 181
Hi CTR,
We agree! It's a nice idea. At the moment this is not possible and it's not a simple change regarding the integration with Halo, so we'll keep it in the back of our mind and hopefully the opportunity to add this type of behavior arises soon Wink
Happy holidays everyone!
CTR
Denmark
Posts 25
CTR replied on Wed, Dec 15 2021 7:46 AM
Hey Khimo.
Can you tell what "Favorites Lists" can be used for under the Interfaces tab ??
Could it be cool to get logos on his Halo for example. 🙂
I just can not find anything on this topic on your Github
Happy holidays to the Team
Khimo Support
Posts 181
The "Favourites Lists" is used for selecting channels on B&O TVs. An equivelent behaviour on the Halo is not currently available, but we'll think about how this could be done ;)
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Thu, Dec 16 2021 5:41 PM
The Lua program below is made to learn to use the Wheel and builds on an example of Khimo.
It does the same as the earlier example with using one button to switch between CD's on the BS9000, BLC connected. But now the CD's are chosen by turning the wheel, confirmed by pressing the button.
Carolpa:
Define a “Virtual Resource” Integer, named as “No”. Place this resource in the area/zone of your Halo remote.
Define a “Virtual Resource” Boolean, named as “Fired”. Place this resource in the area/zone of your Halo remote.
Goto “Macros”:
Make two “Events” :
Halo_Area/Halo_Zone/Halo remote/Your_Halo/WHEEL_TURNED?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx
Halo_Area/Halo_Zone/Halo remote/Your_Halo/BUTTON_RELEASED?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx
  local fired_query = engine.query("Your_Area/Your_Zone/VARIABLE/Fired")
  local fired = fired_query[1].get_boolean("VALUE")
  local cdnummer
  local direction
  local nr_query = engine.query("Your_Area/Your_Zone/VARIABLE/No")
  local nr = nr_query[1].get_number("VALUE")
  if nr==nil then
    nr=1
  end
  if not fired then
    engine.fire("Your_Area/Your_Zone/VARIABLE/Fired/SET?VALUE=true")
    if event.parameters()["OFFSET"] then
      if tonumber(event.parameters()["OFFSET"])>=1 then
        direction= true
      else
        direction=false
      end
      if direction then
        nr = nr + 1
        if nr==7 then
          nr=1
        end
        cdnumber = nr
        engine.fire("Your_Area/Your_Zone/VARIABLE/No/SET?VALUE="..tostring(cdnumber))
      else
        nr = nr - 1
        if nr==0 then
          nr=6
        end
      end
      cdnumber = nr
      engine.fire("Your_Area/Your_Zone/Halo remote/Beoremote Halo Your_Zone/SET_TEXT?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx&TEXT=".."cd"..tostring(cdnumber))
      engine.fire("Your_Area/Your_Zone/Halo remote/Beoremote Halo Your_Zone/SET_WHEEL_VALUE?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx&VALUE="..tostring(math.floor(cdnumber*100/6)))
    else
      engine.fire("Your_Area/Your_Zone/Halo remote/Beoremote Halo Your_Zone/SET_TEXT?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx&TEXT=".."cd"..tostring(nr))
      engine.fire("Your_Area/Your_Zone/Halo remote/Beoremote Halo Your_Zone/SET_WHEEL_VALUE?BUTTON=497f6eca-6276-4993-bfeb-000000810xxx&VALUE="..tostring(math.floor(nr*100/6)))
      engine.fire("Your_Area/Your_Zone/AV renderer/*/Select source?Connector=&Origin=BLC_id&Source Type=CD")
      engine.fire("*/*/AV renderer/BS9000 BLC/Send digit?Digit="..tostring(nr))
    end
  end
  engine.fire("Your_Area/Your_Zone/VARIABLE/Fired/SET?VALUE=false")
end
Tassos
Athens
Posts 323
Tassos replied on Fri, Dec 17 2021 10:06 AM
Hello to all,
I have posted many times my experience with the khimo team and still I feel the need to say that khimo's support is beyond any support I have ever had, especially if you think that they are on the other side and hemisphare of the planet. I sent an email with an issue I had and within 3-4 working days it was solved. All it took it was a google meeting of 30 minutes and the guys came back with the issue solved.
For once more thank you you are the GREATEST!Yes - thumbs up
Seanie_230
UK
Posts 2,278
Seanie_230 replied on Fri, Dec 17 2021 11:21 AM
Tassos:
Hello to all,
I second that, I had a problem when I bought my Bli that it would disappear off my network or sometimes It would not see my devices.
The team at Khimo logged in with me remotely and diagnosed the problem to be that my router was not forwarding broadcast traffic from ethernet / wifi.
Popped to Argos and bought a small switch and everything was great, the support from Khimo to diagnose this with me was brilliant and all in all within two days it was all fixed and sorted.
Great experience everytime.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
beojeff
USA
Posts 2,012
beojeff replied on Sat, Dec 18 2021 12:14 PM
Even after setting the second button on a page on the Halo as the default button, I'm still seeing the first button take the position of the center of the screen -- leaving a blank space to the left. It would really be nice to have the page so that there isn't a blank to the left. It's just unsightly and seems odd.
SirPump
Posts 14
SirPump replied on Mon, Dec 20 2021 8:56 AM
Hi Khimo,
Is it possible to connect  a fireplace to the BLi?
Tassos
Athens
Posts 323
Tassos replied on Mon, Dec 20 2021 12:05 PM
Hello people,
I had some free time and thought of some macros for the NUKI locks.
Everytime the TV turn on BLI checks the battery level of my locks. If any of them is less than 40% a message appears on the screen to check the battery of the lock/locks that have less then 40% battery.
Everytime that my Halo goes active BLI checks the battery level of my locks. If any of them is less than 40% a notification appears to check the battery of the lock/locks that have less than 40% battery.
I have created two buttons on my Halo each controlling a lock. When you tap on the button it tells you if the lock is locked or unlocked by posting the corresponding message as a subtitle. If you turn the wheel rightwards (in my country turning the key rightwards locks the lock) then it locks. If you turn leftwards it unlocks.
In case you need the code I can post it.
An idea I am experimenting is to use the Halo as an alarm clock with snooze function. An easy way to do so is to create an alarm schedule in a product, let's say a beoplay v1, and create a macro which will be executed everytime the Halo goes active. The macro would consist of a pause command or mute command sent to the beoplay v1 and a play command after, let's say, nine minutes. This would be the snooze function. In order to stop the alarm you should turn on the bathroom lights, or create a button that would stop the alarm. ANy suggestions would be more than welcome.
SirPump, I am sure that it could be done. One way it could be to use FIBARO smart implant to put the fireplace on/off. But I am sure any other relay kind of device can do the job.
chucky
Posts 331
chucky replied on Mon, Dec 20 2021 7:44 PM
SirPump:
Hi Khimo,
Depends what remote? Is it IR or Bluetooth rf wifi?
beojeff
USA
Posts 2,012
beojeff replied on Tue, Dec 21 2021 12:57 AM
Khimo-
There are some stability issues that need to be looked into regarding the BLI and Halo remotes. The BLI keeps loosing its connection with the Halos and needs to be power-cycled to regain the connection. I've reserved static IP addresses for the BLI and the Halos, yet this problem persists. Also, it would be nice to have a reboot option in the BLI configuration interface.
chucky
Posts 331
chucky replied on Tue, Dec 21 2021 5:16 AM
beojeff:
Khimo-
Powercycle button would be very nice. I have issues with the KLF200 sometimes. It is not Khimo but Velux, they are really bad with software…. Saves trips to the metercabinet.
Page 14 of 16 (636 items) « First ... < Previous 12 13 14 15 16 Next > | RSS
DigiCert Secured Site Seal
