Curly:Almost time to update your signature block!Very exciting. Post pics of the black lamellas. Or are they “curtains” now? :)Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence RemotePreviously: BeoSound 1 non-GVA
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Those limited edition black lamellas/curtains are very interesting. More textured than the BL18 black plastic. Cool!
Sound impressions vs the 50s?
Razlaw:Thanks all! As for the sound compared to the 50s, to my ears, in my room, at the volumes I listen to, they are very close. So far I tend to think I even like them a bit better?! I find them more relaxing to listen to. I think maybe with the 50s I was always listening to the speakers to hear how perfect they were instead of just enjoying the music. Perhaps I find the sound from the 28s a bit warmer overall, for lack of a better word. Still playing around with the settings and just had to re-pair them. One disappointment to me is that there is no ability to adjust the balance? Beolab 28s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
Razlaw:Thanks all! As for the sound compared to the 50s, to my ears, in my room, at the volumes I listen to, they are very close. So far I tend to think I even like them a bit better?! I find them more relaxing to listen to. I think maybe with the 50s I was always listening to the speakers to hear how perfect they were instead of just enjoying the music. Perhaps I find the sound from the 28s a bit warmer overall, for lack of a better word.Still playing around with the settings and just had to re-pair them.One disappointment to me is that there is no ability to adjust the balance? Beolab 28s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
vlohjr1:Beautiful! Enjoy
oli:Beautiful in black ! I am now thinking to change my frets to black You can adjust the balance in the app, like bass and treble, in the sound section at the bottom
My mistake, you are right, I just checked the sound settings and the balance is not available with bass/treble, I was pretty sure to have seen it somewhere in the app.
Thanks for the info regarding the black lamellas, I will check with my dealer, but as the frets are coming separately it should be possible to order them or find a way to get them, if ever one of them is breaking during the warranty period, they might have some stock available.
oli:My mistake, you are right, I just checked the sound settings and the balance is not available with bass/treble, I was pretty sure to have seen it somewhere in the app.Thanks for the info regarding the black lamellas, I will check with my dealer, but as the frets are coming separately it should be possible to order them or find a way to get them, if ever one of them is breaking during the warranty period, they might have some stock available.
There is no left/right balance adjustment in the app for any of the speakers. I've seen this mentioned a handful of times on the forum by people out of frustration.
But the 28s look great and I'm super interested in how you end up finding the 28s vs. 50s.
Happy Friday to all.
There is no balance for the speakers directly that I'm aware of, but you can adjust balance through the BV. I have my 28s, 50s and 18s set up that way for various listening scenarios though the controls in my Harmonys.
--Beovision Harmony 77, Beovision Harmony 65 x2, Beovision Contour 48, LG GX 65/Beosound Stage/STB StandBeolab 50s, Beolab 28s, Beolab 18s x3, Beolab 19, Beoplay A9, Beosound Edge, Beosound 2 x2, Beosound 1 x2, Beosound Level x2, Beosound Core x2, Beoplay M3, Beosound 9000, Beogram TX2, Beogram 6500 White Edition, 4000c (on order), Beoremote One x8, Beoremote Halo x3, BLC NL/MLBeoplay H95 x3, Beoplay EQ x2, Beoplay E8, Beoplay E8 Sport, Beosound A1 x2
On the BV it’s
Speaker Groups
Speaker Distance
Speaker Level
to get the balance/image as you like it.
love the black frets 👍🏻
Ouch!
Very nice Razlaw, i personally like the 28s in black with the black lamellas they look super nice… Enjoy
Beoplay A2
oli:And don’t forget to change the default compressed LC3 communication between both speaker to full PCM (in Audio Quality)
Razlaw:Thanks again for all of the compliments. Now I hope someone can help with a problem, while I wait to hear back from my dealer. 28s were installed completely wireless with powerlink to my BV7, one for each speaker. Everything worked but there was some interference from other wifi devices with the wireless connection between the two 28s. As a result the two 28s are now connected with an Ethernet cable. They are now working great. Problem is when I turn on the BV7, the primary 28 does not turn on. The secondary one does. I have checked the connections. I have checked for sound in the speaker menu. Nothing. Any thoughts? Thanks! Edit….a reboot solved it. Beolab 28s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
jowus:Hi Razlaw, Congrats on your New Baby. It’s very Nice in Black. But, as much as, l like to see the 28’s, i find it very astounding with the Harmony! It looks a little bit odd with your TV though! Maybe it’s time to break the bank again!
I understand you have connected the 28's to each other with ethernet. Did you then connect the main speaker to WiFi?
and what is the advantage of this setup?
Ekl:I understand you have connected the 28's to each other with ethernet. Did you then connect the main speaker to WiFi?and what is the advantage of this setup?
Ok, thanks!
MartinRK:Hi Razlaw Can you tell more about how they work together with the BV7? Can you watch the BV without sound, and at the same time listen to music from the Beolab 28? and if you use them with the BV through PL, and then starts to stream music to them, do they switch to music, so streaming is prioritized over PL or the other way around?
MartinRK:Hi RazlawCan you tell more about how they work together with the BV7?Can you watch the BV without sound, and at the same time listen to music from the Beolab 28?and if you use them with the BV through PL, and then starts to stream music to them, do they switch to music, so streaming is prioritized over PL or the other way around?
Razlaw, any new feelings on your 28s? Perhaps especially compared to your former 50s?
I hope the connection issues have been resolved.
Curly:Razlaw, any new feelings on your 28s? Perhaps especially compared to your former 50s? I hope the connection issues have been resolved. Currently: BeoLab 17, BeoLab 18, BeoSound Core, Beosound Level, Beosound A1 2nd Gen, BeoPlay S8 Connection Hub, Halo, Essence Remote Previously: BeoSound 1 non-GVA
Hi, I’m new to the forum. Can anybody help me.
I have a harmony with the BO28 and after 2 month one of the subwoofers was faulty and rattling. My local BO changed this. But now, when I’m watching TV I get clicking noises every 15/20 minutes from the left tower. Not from the subwoofer. But clicking from the speaker. It sounds like static popping noises but I’m aware BO28 won’t do this.
has anybody else had issues with the BO28 and more importantly does anybody else experience the popping/clicking noises ?
Welcome to the forum.
On a brand new speaker that is unquestionably under warranty and has already suffered from a warrantied repair, IMHO, this absolutely merits outreach to your dealer.
Cheshire1993:Hi, I’m new to the forum. Can anybody help me. I have a harmony with the BO28 and after 2 month one of the subwoofers was faulty and rattling. My local BO changed this. But now, when I’m watching TV I get clicking noises every 15/20 minutes from the left tower. Not from the subwoofer. But clicking from the speaker. It sounds like static popping noises but I’m aware BO28 won’t do this. has anybody else had issues with the BO28 and more importantly does anybody else experience the popping/clicking noises ?
Hi, do you hear these noises when you use the volume control?
I have the same problem, but did find out that it is one of the powerlink connections. Probably a grounding issue.
