BeoLiving news & support from Khimo!
This post has 635 Replies | 20 Followers
Tassos
Athens
Posts 323
Tassos replied on Wed, Jan 29 2020 11:48 AM
Hello,
I have recently installed a Rako RMT-Pill to control my lights. I have made a macro to turn them on and off using a virtual button with led. When I press the button lights turn on. When I hold the button the lights should turn off but they start dimming a bit but then they stop and turn on again. If I fire the command from the BLI interface everything works fine. Also everything works fine if I send the command through the Rako app from my phone.
Any ideas?
Thank you
Anastasios
Khimo Support
Posts 181
beojeff:
You didn't answer the second part of my question. Is there any advantage to using a BLGW over an MLGW with the BLI?
Hi beojeff,
There is no advantage, the driver behaves the same if the MasterLink interface is a BLGW or a MLGW.
Best,
the Khimo team.-
Khimo Support
Posts 181
Tassos:
Hello,
Any ideas?
Thank you
Anastasios
Hi Anastasios,
When you say "when I hold the button", you mean on the BLI app?
Can you share your macro configuration so we can take a look at it? (a couple of screenshots will do)
Best,
the Khimo team.-
beojeff
USA
Posts 2,012
beojeff replied on Wed, Jan 29 2020 1:25 PM
Could multiple MLGW/BLGW be used with the BLI? For example, if someone wanted to reduce the lengths of ML cabling throughout his home. In addition to my BLGW, I have 2 MLGWs in storage that I'm not currently using.
Khimo Support
Posts 181
DocLeisure:
Hello Khimo Team,
thanks for the answer and sorry for insisting ;-)
Does "on the first Version" mean that there are further versions in planning that would offer an extended experience for the BeoSound 5 - covers, search & PlayQue.
Really looking forward - please.make it possible!
Best regards
Doc Leisure
Hi Doc,
Direct play queue management on the BeoSound 5 from the ML driver is not on our current roadmap, but it is a feature that could be added if there is interest from the users.
Best regards,
the Khimo team.-
Khimo Support
Posts 181
beojeff:
Hi beojeff,
From the BLI perspective, it is perfectly possible: you should add a system per BLGW/MLGW and configure the addresses and resources for each one.
Regarding the ML side, you could create separate ML networks, and assign the node numbers on each separately (note that is something we have not tried or tested yet).
Best regards,
the Khimo team.-
Tassos
Athens
Posts 323
Tassos replied on Wed, Jan 29 2020 2:19 PM
Khimo Support:
Tassos:
Hello,
Any ideas?
Thank you
Anastasios
Hi Anastasios,
Best,
the Khimo team.-
Thanks for the prompt response.
Yes I mean the button on the BLI app.
The event and command are as follows:
Event
Main/Family Room/BUTTON/Lights/
HOLD
Main/Family Room/AV renderer/BeoPlay-V1/
Light?Action=Continue&Command=FUNCTION_15
Add event Capture Close
CommandWait ( s / ms )
_SET STATE?STATE=0
Main/Family Room/DIMMER/*/
SET?LEVEL=0
beojeff
USA
Posts 2,012
beojeff replied on Wed, Jan 29 2020 2:37 PM
Khimo Support:
beojeff:
Hi beojeff,
Best regards,
the Khimo team.-
I would think that each ML network would need to have its own system on the BLI.
Khimo Support
Posts 181
beojeff:
Hi beojeff,
Yes, I tried to mean that on the previous post: one MLGW/BLGW per ML network, and one system on the BLI per MLGW/BLGW.
Best,
the Khimo team.-
beojeff
USA
Posts 2,012
beojeff replied on Wed, Jan 29 2020 2:55 PM
Khimo Support:
beojeff:
Hi beojeff,
Best,
the Khimo team.-
Ah. So you can add multiple systems of the driver on the BLI?
Khimo Support
Posts 181
beojeff:
 Yes!
Tassos
Athens
Posts 323
Tassos replied on Fri, Jan 31 2020 11:05 AM
Any news on the Rako RMT-PILL issue?
Khimo Support
Posts 181
Tassos:
Hi Tassos,
We made some tests and the PRESS/HOLD cycle works as expected. Please note that when you HOLD a button, you are also pressing it, though sending 2 events: PRESS followed by HOLD (and an eventual RELEASE). Maybe this fact is causing the misbehavior on your lights?
What you could do is make the button led follow the state of the light (on when the lights are on and viceversa), and turn on or off the lights in the same macro.
Best,
the Khimo team.-
Tassos
Athens
Posts 323
Tassos replied on Fri, Jan 31 2020 5:11 PM
Khimo Support:
Tassos:
Hi Tassos,
Best,
the Khimo team.-
Hello again, do you mean something like this?
function(event, engine)
  -- Define the resource address in your project:
  local dimmer_level_address = "Main/Family Room/DIMMER/*"
  local lights_button_address = "Main/Family Room/BUTTON/Lights"
   -- Get dimmer level
   local dimmer_level = engine.query(dimmer_level_address)[1]
   if dimmer_level.get("LEVEL") == "0" then
       -- the lights button led is off!
       engine.fire(lights_button_address .. "/_SET STATE?STATE=0")
   else
       -- the lights button led is on!
       engine.fire(lights_button_address .. "/_SET STATE?STATE=1")
   end
end
Khimo Support
Posts 181
Tassos:
   -- Get dimmer level
   else
   end
end
Hi Tassos,
Yes, if that macro gets fired every time the DIMMER on Family Room is updated, then the led of the BUTTON named Lights will be updated as well.
Note that this may not work if you have several DIMMERs on the Family Room, since you are checking against the state of the first one...
Best regards,
the Khimo team.-
jg1976
Posts 63
jg1976 replied on Sat, Feb 1 2020 10:16 AM
Dear Khimo,
I hope this is an easy question for you to answer, maybe very basic however i just recently updated from MLGW to NLGW...
In both app beolink 2 & beoliving it always pop up ”select a tab to control your room” and ”select a source to start listening”. Most annoying.. how can I disable this?
Tassos
Athens
Posts 323
Tassos replied on Sat, Feb 8 2020 4:02 PM
Hello all,
is there any way that I can match basic ir commands from a beoremote one to an stb not supported from the puc database? For example when I press the P+ button on my beoremote one the "channel up" command is sent from my ip2ir itach ir blaster.
beojeff
USA
Posts 2,012
beojeff replied on Sat, Feb 8 2020 4:29 PM
Tassos:
Hello all,
The Global Caché Itach IR transmitter is a good solution. With it, you can use macros to blast just about any IR command to anything. The IR codes for most common devices are found on their website. You just cut and paste them into the system resource on the BLGW. If the IR codes are not on their website, you can use the device to learn them -- with mixed results.
Note that when requested to use a paperclip into the hole on the global caché device you MUST actually use a METAL paperclip and not one coated with plastic. They fail to tell you this detail.
However, I've found that BeoCare is fairly good about adding entries into the PUC database when requested.
Tassos
Athens
Posts 323
Tassos replied on Sun, Feb 9 2020 11:23 AM
beojeff:
Tassos:
Hello all,
Thanks for the reply. I have already copied the ir commands. My question is how to make the P+ button of the beoremote one trigger an action. It is not available as an event.
Khimo Support
Posts 181
Tassos:
Hi @Tassos!
As described by @beojeff, you can create macros that use global cache to send IR commands, but you cannot activate the macros with the normal P+ button of your BeoRemote One.
You can only use the Light and Control commands from the BeoRemote as macro triggers. In the following link you can find more details and an example of activating a macro with a Light commands: https://khimo.github.io/bli-guides/how-tos/howto-OneRemote-BLI
Best,
the Khimo team.-
gandhilovkesh
Posts 7
Hello All
i need to know how i can control shades, lighting, CCTV, NON B&o Tv like LG Tv,Network Drive,HVAC.
do i need to use control4, crestron, processor devices to control all the equipment?
any another knowledge if available for this then please share, or anyone is using BLI on their site or at there residence please share Video and Photos.
Many Thanks
Lovkesh
+919992906767
Aleksei
Russia
Posts 84
Aleksei replied on Thu, Feb 13 2020 12:17 PM
I would love to use this driver too.
The module looks very promising.
https://beointegration.wordpress.com/
1:BV7+BL7.1+BS4+BL6000+BV6+BL2000+MLGW+Beo4
2:BV7+BL7.4+BL3500+BM5+BL3+Lutron GE/Sivoia QS+HikVision+Dune+LinTronic+BLGW+Beo4+Beo5+Essence remote+BeoTime+BeoLinkPC+BL4+KNX+... BeoMaster900
beojeff
USA
Posts 2,012
beojeff replied on Mon, Feb 17 2020 11:10 PM
Do you have a timeframe for when you will be working on a driver for the Ikea Tradfri? There are others on this forum who have expressed an interest in this driver.
Khimo Support
Posts 181
gandhilovkesh:
Hello @gandhilovkesh,
The BLI can control many devices (eg: KNX, Lutron Shades and Dimmers, etc).
You can find a list of all currently supported systems at: https://khimo.github.io/help_drivers
In addition, if a controller is not available for a given system, if the system has a serial or HTTP protocol, it is generally possible to obtain a basic integration using the "Custom Strings" or "Custom HTTP" drivers.
Best regards,
the Khimo team.-
Khimo Support
Posts 181
beojeff:
Hi @beojeff,
There is still no official and open API for Ikea Trådfri.
Best,
the Khimo team.-
beojeff
USA
Posts 2,012
beojeff replied on Tue, Feb 18 2020 10:41 AM
Khimo Support:
beojeff:
Hi @beojeff,
Best,
the Khimo team.-
Perhaps taking a look here might help:
https://learn.pimoroni.com/tutorial/sandyj/controlling-ikea-tradfri-lights-from-your-pi
jg1976
Posts 63
jg1976 replied on Sat, Feb 29 2020 3:49 PM
Dear Khimo!
In Beoliving App, when I start to play a playlist from Deezer, it only put 26 tracks in queue?
After those 26 tracks has played it will stop.
Is it possible to do so ”all” the tracks will be in queue (normally you have more than 26...)
jg1976
Posts 63
jg1976 replied on Sat, Feb 29 2020 3:50 PM
Sorry, forget to mention I am playing from beosound core... In Beolink Network..
Khimo Support
Posts 181
jg1976:
Dear Khimo!
Hi @jg1976,
In the next release, it will be possible to add all the tracks at once.
Best,
the Khimo team.-
jg1976
Posts 63
jg1976 replied on Tue, Mar 3 2020 12:57 PM
Thank you soo much!!!
Michael
Atlanta
Posts 98
Michael replied on Tue, Mar 3 2020 3:25 PM
Being a casual Khimo question I didn't think this needed a whole new thread but I was just curious of how the Collapse command for macros is envisioned to be utilized.
I understand the description but wasn't sure when it might be appropriate.
Michael
Atlanta
Posts 98
Double post.
Khimo Support
Posts 181
Michael:
COLLAPSE will execute all remaining commands in a (possibly) ongoing macro, but with no Wait delays between commands. Therefore, the macro execution ends fast and all the commands are sent.
Imagine you have a macro that runs a long demonstration that must finish at the user's request. If you simply CANCEL it, you can leave things in an unknown state, in contrast, if you COLLAPSE it, you are sure that you will reach the final state, because all commands are sent.
1990
Posts 521
1990 replied on Thu, Mar 5 2020 8:20 AM
So the new BeoSound Balance has been announced, and it doesn't feature Multiroom.
So now I'm curious what the way forward is for the BLI. Plug a Core into the Line-in as a quick fix? Or will the BLI use the Homekit/Google Home api's as well in future?
PaulGiles
Posts 218
PaulGiles replied on Fri, Mar 6 2020 10:25 PM
Is there no ability to actually speak to anyone at Khimo?
Seems ludicrous that distant emails and a forum are the only way of communication?
I have made repeated requests to get remote support or speak to someone yet all I receive is an email reply a couple days later.
Not what I expect for the money paid for the PRO subscription.
Normann
Posts 277
Normann replied on Mon, Mar 9 2020 6:57 AM
In the Beoliving app (version 1.5.4.533) I no longer have the possibility to log on to Tune In or make   choice on selecting a radio station.
Anyone else experiencing this?
Khimo Support
Posts 181
Dear Paul,
You can call to the phone listed in our webpage, but it is generally better to contact us by email at support@khimo.com, by sending a full description of your problem and attaching a service report. In any case, we can always coordinate an online meeting if it is needed.
With respect to the PRO update, just to clarify, it is a software license that enables the full power of our hardware, including remote access. It is not a subscription.
Best regards,
the Khimo team.-
Khimo Support
Posts 181
Normann:
In the BeoLiving app (version 1.5.4.533) I no longer have the possibility to log on to Tune In or make   choice on selecting a radio station.
Hi @Normann,
Are you using the BLGW or the BLI?
In the case of BLGW, you must configure the TuneIn credentials directly on the audio product (for example: Use of BeoTool), the BeoLiving application will only list the favorite stations that you have defined in the TuneIn account registered in the AV product.
Best,
The Khimo team.-
Khimo Support
Posts 181
Hi @1990
Currently, BeoSound Balance is not integrated with the BLI, but this does not mean that all future B&O products will not be integrable.
Best,
the Khimo team.-
Normann
Posts 277
Normann replied on Mon, Mar 9 2020 3:31 PM
Khimo Support:
Normann:
Hi @Normann,
Best,
The Khimo team.-
I am using the BLGW.
The TuneIn works just fine with the Bang Olufsen app, so the credentials should be correct registrated on the product (A9).
Page 5 of 16 (636 items) « First ... < Previous 3 4 5 6 7 Next > ... Last » | RSS
DigiCert Secured Site Seal
