Hello,
I have recently installed a Rako RMT-Pill to control my lights. I have made a macro to turn them on and off using a virtual button with led. When I press the button lights turn on. When I hold the button the lights should turn off but they start dimming a bit but then they stop and turn on again. If I fire the command from the BLI interface everything works fine. Also everything works fine if I send the command through the Rako app from my phone.
Any ideas?
Thank you
Anastasios
beojeff: You didn't answer the second part of my question. Is there any advantage to using a BLGW over an MLGW with the BLI?
Hi beojeff,
There is no advantage, the driver behaves the same if the MasterLink interface is a BLGW or a MLGW.
Best,
the Khimo team.-
Tassos: Hello, I have recently installed a Rako RMT-Pill to control my lights. I have made a macro to turn them on and off using a virtual button with led. When I press the button lights turn on. When I hold the button the lights should turn off but they start dimming a bit but then they stop and turn on again. If I fire the command from the BLI interface everything works fine. Also everything works fine if I send the command through the Rako app from my phone. Any ideas? Thank you Anastasios
Hi Anastasios,
When you say "when I hold the button", you mean on the BLI app?
Can you share your macro configuration so we can take a look at it? (a couple of screenshots will do)
Could multiple MLGW/BLGW be used with the BLI? For example, if someone wanted to reduce the lengths of ML cabling throughout his home. In addition to my BLGW, I have 2 MLGWs in storage that I'm not currently using.
DocLeisure: Hello Khimo Team, thanks for the answer and sorry for insisting ;-) Does "on the first Version" mean that there are further versions in planning that would offer an extended experience for the BeoSound 5 - covers, search & PlayQue. Really looking forward - please.make it possible! Best regards Doc Leisure
Hello Khimo Team,
Best regards
Doc Leisure
Hi Doc,
Direct play queue management on the BeoSound 5 from the ML driver is not on our current roadmap, but it is a feature that could be added if there is interest from the users.
Best regards,
beojeff: Could multiple MLGW/BLGW be used with the BLI? For example, if someone wanted to reduce the lengths of ML cabling throughout his home. In addition to my BLGW, I have 2 MLGWs in storage that I'm not currently using.
From the BLI perspective, it is perfectly possible: you should add a system per BLGW/MLGW and configure the addresses and resources for each one.
Regarding the ML side, you could create separate ML networks, and assign the node numbers on each separately (note that is something we have not tried or tested yet).
Khimo Support: Tassos: Hello, I have recently installed a Rako RMT-Pill to control my lights. I have made a macro to turn them on and off using a virtual button with led. When I press the button lights turn on. When I hold the button the lights should turn off but they start dimming a bit but then they stop and turn on again. If I fire the command from the BLI interface everything works fine. Also everything works fine if I send the command through the Rako app from my phone. Any ideas? Thank you Anastasios Hi Anastasios, When you say "when I hold the button", you mean on the BLI app? Can you share your macro configuration so we can take a look at it? (a couple of screenshots will do) Best, the Khimo team.-
Thanks for the prompt response.
Yes I mean the button on the BLI app.
The event and command are as follows:
Add event Capture Close
Khimo Support: beojeff: Could multiple MLGW/BLGW be used with the BLI? For example, if someone wanted to reduce the lengths of ML cabling throughout his home. In addition to my BLGW, I have 2 MLGWs in storage that I'm not currently using. Hi beojeff, From the BLI perspective, it is perfectly possible: you should add a system per BLGW/MLGW and configure the addresses and resources for each one. Regarding the ML side, you could create separate ML networks, and assign the node numbers on each separately (note that is something we have not tried or tested yet). Best regards, the Khimo team.-
I would think that each ML network would need to have its own system on the BLI.
beojeff: I would think that each ML network would need to have its own system on the BLI.
Yes, I tried to mean that on the previous post: one MLGW/BLGW per ML network, and one system on the BLI per MLGW/BLGW.
Khimo Support: beojeff: I would think that each ML network would need to have its own system on the BLI. Hi beojeff, Yes, I tried to mean that on the previous post: one MLGW/BLGW per ML network, and one system on the BLI per MLGW/BLGW. Best, the Khimo team.-
Ah. So you can add multiple systems of the driver on the BLI?
beojeff: Ah. So you can add multiple systems of the driver on the BLI?
Yes!
Any news on the Rako RMT-PILL issue?
Tassos: Any news on the Rako RMT-PILL issue?
Hi Tassos,
We made some tests and the PRESS/HOLD cycle works as expected. Please note that when you HOLD a button, you are also pressing it, though sending 2 events: PRESS followed by HOLD (and an eventual RELEASE). Maybe this fact is causing the misbehavior on your lights?
What you could do is make the button led follow the state of the light (on when the lights are on and viceversa), and turn on or off the lights in the same macro.
Khimo Support: Tassos: Any news on the Rako RMT-PILL issue? Hi Tassos, We made some tests and the PRESS/HOLD cycle works as expected. Please note that when you HOLD a button, you are also pressing it, though sending 2 events: PRESS followed by HOLD (and an eventual RELEASE). Maybe this fact is causing the misbehavior on your lights? What you could do is make the button led follow the state of the light (on when the lights are on and viceversa), and turn on or off the lights in the same macro. Best, the Khimo team.-
Hello again, do you mean something like this?
function(event, engine) -- Define the resource address in your project: local dimmer_level_address = "Main/Family Room/DIMMER/*" local lights_button_address = "Main/Family Room/BUTTON/Lights" -- Get dimmer level local dimmer_level = engine.query(dimmer_level_address)[1]
if dimmer_level.get("LEVEL") == "0" then -- the lights button led is off! engine.fire(lights_button_address .. "/_SET STATE?STATE=0") else -- the lights button led is on! engine.fire(lights_button_address .. "/_SET STATE?STATE=1") end end
Tassos: Hello again, do you mean something like this? function(event, engine) -- Define the resource address in your project: local dimmer_level_address = "Main/Family Room/DIMMER/*" local lights_button_address = "Main/Family Room/BUTTON/Lights" -- Get dimmer level local dimmer_level = engine.query(dimmer_level_address)[1] if dimmer_level.get("LEVEL") == "0" then -- the lights button led is off! engine.fire(lights_button_address .. "/_SET STATE?STATE=0") else -- the lights button led is on! engine.fire(lights_button_address .. "/_SET STATE?STATE=1") end end
Yes, if that macro gets fired every time the DIMMER on Family Room is updated, then the led of the BUTTON named Lights will be updated as well.
Note that this may not work if you have several DIMMERs on the Family Room, since you are checking against the state of the first one...
Dear Khimo,
Hello all,
is there any way that I can match basic ir commands from a beoremote one to an stb not supported from the puc database? For example when I press the P+ button on my beoremote one the "channel up" command is sent from my ip2ir itach ir blaster.
Tassos: Hello all, is there any way that I can match basic ir commands from a beoremote one to an stb not supported from the puc database? For example when I press the P+ button on my beoremote one the "channel up" command is sent from my ip2ir itach ir blaster.
The Global Caché Itach IR transmitter is a good solution. With it, you can use macros to blast just about any IR command to anything. The IR codes for most common devices are found on their website. You just cut and paste them into the system resource on the BLGW. If the IR codes are not on their website, you can use the device to learn them -- with mixed results.
Note that when requested to use a paperclip into the hole on the global caché device you MUST actually use a METAL paperclip and not one coated with plastic. They fail to tell you this detail.
However, I've found that BeoCare is fairly good about adding entries into the PUC database when requested.
beojeff: Tassos: Hello all, is there any way that I can match basic ir commands from a beoremote one to an stb not supported from the puc database? For example when I press the P+ button on my beoremote one the "channel up" command is sent from my ip2ir itach ir blaster. The Global Caché Itach IR transmitter is a good solution. With it, you can use macros to blast just about any IR command to anything. The IR codes for most common devices are found on their website. You just cut and paste them into the system resource on the BLGW. If the IR codes are not on their website, you can use the device to learn them -- with mixed results. Note that when requested to use a paperclip into the hole on the global caché device you MUST actually use a METAL paperclip and not one coated with plastic. They fail to tell you this detail. However, I've found that BeoCare is fairly good about adding entries into the PUC database when requested.
Thanks for the reply. I have already copied the ir commands. My question is how to make the P+ button of the beoremote one trigger an action. It is not available as an event.
Tassos: is there any way that I can match basic ir commands from a beoremote one to an stb not supported from the puc database? For example when I press the P+ button on my beoremote one the "channel up" command is sent from my ip2ir itach ir blaster.
Hi @Tassos!
As described by @beojeff, you can create macros that use global cache to send IR commands, but you cannot activate the macros with the normal P+ button of your BeoRemote One.
You can only use the Light and Control commands from the BeoRemote as macro triggers. In the following link you can find more details and an example of activating a macro with a Light commands: https://khimo.github.io/bli-guides/how-tos/howto-OneRemote-BLI
Hello All
i need to know how i can control shades, lighting, CCTV, NON B&o Tv like LG Tv,Network Drive,HVAC.
do i need to use control4, crestron, processor devices to control all the equipment?
any another knowledge if available for this then please share, or anyone is using BLI on their site or at there residence please share Video and Photos.
Many Thanks
Lovkesh
+919992906767
I would love to use this driver too.
The module looks very promising.
https://beointegration.wordpress.com/
1:BV7+BL7.1+BS4+BL6000+BV6+BL2000+MLGW+Beo4
2:BV7+BL7.4+BL3500+BM5+BL3+Lutron GE/Sivoia QS+HikVision+Dune+LinTronic+BLGW+Beo4+Beo5+Essence remote+BeoTime+BeoLinkPC+BL4+KNX+... BeoMaster900
Do you have a timeframe for when you will be working on a driver for the Ikea Tradfri? There are others on this forum who have expressed an interest in this driver.
gandhilovkesh:i need to know how i can control shades, lighting, CCTV, NON B&o Tv like LG Tv,Network Drive,HVAC.
Hello @gandhilovkesh,The BLI can control many devices (eg: KNX, Lutron Shades and Dimmers, etc).You can find a list of all currently supported systems at: https://khimo.github.io/help_driversIn addition, if a controller is not available for a given system, if the system has a serial or HTTP protocol, it is generally possible to obtain a basic integration using the "Custom Strings" or "Custom HTTP" drivers.Best regards,the Khimo team.-
beojeff: Do you have a timeframe for when you will be working on a driver for the Ikea Tradfri? There are others on this forum who have expressed an interest in this driver.
Hi @beojeff,
There is still no official and open API for Ikea Trådfri.
Khimo Support: beojeff: Do you have a timeframe for when you will be working on a driver for the Ikea Tradfri? There are others on this forum who have expressed an interest in this driver. Hi @beojeff, There is still no official and open API for Ikea Trådfri. Best, the Khimo team.-
Perhaps taking a look here might help:
https://learn.pimoroni.com/tutorial/sandyj/controlling-ikea-tradfri-lights-from-your-pi
jg1976:Dear Khimo! In Beoliving App, when I start to play a playlist from Deezer, it only put 26 tracks in queue? After those 26 tracks has played it will stop. Is it possible to do so ”all” the tracks will be in queue (normally you have more than 26...)
Hi @jg1976,
In the next release, it will be possible to add all the tracks at once.
Thank you soo much!!!
Being a casual Khimo question I didn't think this needed a whole new thread but I was just curious of how the Collapse command for macros is envisioned to be utilized.
I understand the description but wasn't sure when it might be appropriate.
Double post.
Michael: Being a casual Khimo question I didn't think this needed a whole new thread but I was just curious of how the Collapse command for macros is envisioned to be utilized.
COLLAPSE will execute all remaining commands in a (possibly) ongoing macro, but with no Wait delays between commands. Therefore, the macro execution ends fast and all the commands are sent.
So the new BeoSound Balance has been announced, and it doesn't feature Multiroom.
So now I'm curious what the way forward is for the BLI. Plug a Core into the Line-in as a quick fix? Or will the BLI use the Homekit/Google Home api's as well in future?
In the Beoliving app (version 1.5.4.533) I no longer have the possibility to log on to Tune In or make choice on selecting a radio station.
Anyone else experiencing this?
Dear Paul,You can call to the phone listed in our webpage, but it is generally better to contact us by email at support@khimo.com, by sending a full description of your problem and attaching a service report. In any case, we can always coordinate an online meeting if it is needed.With respect to the PRO update, just to clarify, it is a software license that enables the full power of our hardware, including remote access. It is not a subscription.Best regards,the Khimo team.-
Normann:In the BeoLiving app (version 1.5.4.533) I no longer have the possibility to log on to Tune In or make choice on selecting a radio station.
Hi @Normann,Are you using the BLGW or the BLI?In the case of BLGW, you must configure the TuneIn credentials directly on the audio product (for example: Use of BeoTool), the BeoLiving application will only list the favorite stations that you have defined in the TuneIn account registered in the AV product.Best,
The Khimo team.-
1990: So now I'm curious what the way forward is for the BLI. Plug a Core into the Line-in as a quick fix? Or will the BLI use the Homekit/Google Home api's as well in future?
Hi @1990
Currently, BeoSound Balance is not integrated with the BLI, but this does not mean that all future B&O products will not be integrable.
Khimo Support: Normann:In the BeoLiving app (version 1.5.4.533) I no longer have the possibility to log on to Tune In or make choice on selecting a radio station. Hi @Normann,Are you using the BLGW or the BLI?In the case of BLGW, you must configure the TuneIn credentials directly on the audio product (for example: Use of BeoTool), the BeoLiving application will only list the favorite stations that you have defined in the TuneIn account registered in the AV product.Best, The Khimo team.-
I am using the BLGW.
The TuneIn works just fine with the Bang Olufsen app, so the credentials should be correct registrated on the product (A9).
