BeoVision Contour
This post has 315 Replies | 2 Followers
moxxey
South West, UK
Posts 5,359
moxxey replied on Thu, Nov 19 2020 12:49 PM
My dealer told me that the Contour does NOT use an off-the-shelf Stage.
ie. you can't buy a Contour frame and drop in an existing Stage. It used a slightly customised version. Explains the oak fret, too.
moxxey
South West, UK
Posts 5,359
moxxey replied on Thu, Nov 19 2020 12:51 PM
Mikipidia:
moxxey:
More seriously though, can I take the 'spare' Stage I have here and use it with this frame and an a panel?
Yes you can!Big Smile
No you can't. Are you just assuming or have some knowledge? My dealer says this isn't possible.
Mikipidia
Posts 2,169
Mikipidia replied on Thu, Nov 19 2020 1:06 PM
They take the alu edge off and slide it in the frame, same for the panel. I've seen it yesterday. if this is ''custom'' then I guess yes, but it's literally the stage with out the alu frame and nothing else is different. Even the holes for the front cover are the same, inside it also has the two lights you see on the Stage.
I asked how to built the contour and that's what I was told and also could verify by seeing it Smile
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
poodleboy
Posts 303
poodleboy replied on Thu, Nov 19 2020 1:26 PM
The spec says the TV has 4 HDMI input. Will the Beoremote control them?
andy_js
Englandshire
Posts 223
andy_js replied on Thu, Nov 19 2020 1:38 PM
In theory you could using HDMI-CEC.
Emil Jensen
Denmark
Posts 766
Mikipidia:
Yes but in the pricelist I found that you could buy a Cheaper version of the Stage without the Frame, So you don need to throw out frames ;)
moxxey
South West, UK
Posts 5,359
moxxey replied on Thu, Nov 19 2020 2:08 PM
Mikipidia:
I'll ask him again. I guess dealer's are lacking all the information they need so far. I wonder if they can buy a Contour without the Stage though.
1990
Posts 521
1990 replied on Thu, Nov 19 2020 2:10 PM
moxxey:
The "naked" Stage is featured in the pricelist as a stand alone item with its own product number, so I guess you can.
KMA
Posts 621
KMA replied on Thu, Nov 19 2020 2:39 PM
BeoSound Stage Floor Stand: 700€
LG CX 48": 1.199€ (or 55" for 1.299€)
BeoSound Stage: 1.500€
BeoRemote One: 300€
Total: 3.699€ or 2.999€ with wall brackets.
Contour: starting from 5.299€ with wall bracket. The aluminum frame is pretty expensive!
48" is a bit too small for me, but I really like Contour's design. I'd take a 55" version over Eclipse any time.
Any info on the Contour floor stand price?
KMA
B&O product history since 1991: Ridiculously long to list in a signature.
1990
Posts 521
1990 replied on Thu, Nov 19 2020 2:44 PM
KMA:
LG CX 48": 1.190€ (or 55" for 1.299€)
Where are you located? If you can get CX48 for 1.190 you can get the Contour for less too. In the Netherlands CX48 still retails for 1.699.
KMA
Posts 621
KMA replied on Thu, Nov 19 2020 2:46 PM
1990:
I'm located in Finland. Just checked the 48" CX price: https://www.verkkokauppa.com/fi/product/24134/nkfdh/LG-OLED48CX-48-4K-Ultra-HD-OLED-televisio
It's the time of year when CX prices (prices of LG's this year's models in general) start to come down as 2021 models are around the corner.
KMA
1990
Posts 521
1990 replied on Thu, Nov 19 2020 2:53 PM
Wow, very good price!
At B&O Copenhagen pricing is as follows
Contour with cloth + wall bracket: 5.360
Contour with cloth + table stand: 5.460
Contour with cloth + floor stand: 5.680
Wood + 690
KMA
Posts 621
KMA replied on Thu, Nov 19 2020 2:54 PM
1990:
Contour with cloth + wall bracket: 5.360 Contour with cloth + table stand: 5.460 Contour with cloth + floor stand: 5.680
Wood + 690
So the floor stand is only ~300€ extra. That's not bad at all.
KMA
Sandyb
Posts 2,186
Sandyb replied on Thu, Nov 19 2020 2:57 PM
KMA:
BeoRemote One: 300€
Any info on the Contour floor stand price? KMA
I’d get a 55 version for my bedroom too, in theory.
But no power link , no motorised wall bracket - too limiting for the price
jakob77k
Posts 5
jakob77k replied on Thu, Nov 19 2020 3:05 PM
I fully agree. I think the package look very nice, and it could be seen as a possible replacement of my trusted BV10-40, but the lack of Power Link connections is frustrating, having invested in B&O Lab 18's, 4000's and Lab2 to have surround. Wonder if it is possible to fix this by adding an Almando box to the Contour and still use the built in speaker as center channel ? Spoke to a dealer today advising this was not possible, and he wanted me to buy the Eclipse instead. He may have had his reasons for not telling the full story. Anyone in the forum having any knowledge of whether the Almando box would be a possibility ?? Adding the cost of an Almando box would still be cheaper than going for the Eclipse mk II.
jakob77k
Posts 5
moxxey
South West, UK
Posts 5,359
moxxey replied on Thu, Nov 19 2020 3:17 PM
Sandyb:
There won't be a 55" version (that's the Eclipse) as it's using the Stage technology, which just happens to be the same width as the 48".
ie. a 55" would require a brand new speaker, which makes the entire project custom and not using existing components. Not going to happen.
kuyttendaele
Posts 707
Correct... the Contour is 48" only. A 55" would be in the price range of the Ecliple with less features
KMA
Posts 621
KMA replied on Thu, Nov 19 2020 3:28 PM
moxxey:
I'm sure you are correct and that this is B&O's reasoning as well.
However, Stage would fit in a 55" Contour frame: just small spacers at both ends of Stage, inside the frame, and slightly longer speaker covers. I can see how this could be done. Easily, actually.
KMA
Sandyb
Posts 2,186
Sandyb replied on Thu, Nov 19 2020 4:59 PM
moxxey:
I’m aware, was just wish casting for the purpose of illustration
moxxey
South West, UK
Posts 5,359
moxxey replied on Thu, Nov 19 2020 5:28 PM
KMA:
Guys, we discuss things that just aren't going to happen.
The 48" Contour is B&O's "basic" entry-level TV. If you want to move up to 55" or higher, you have the Eclipse. You won't get a 55" Contour. No clue why we're even thinking it will happen.
Sycamore
South East, UK
Posts 6
Sycamore replied on Thu, Nov 19 2020 5:42 PM
It looks great. But seems incredibly overpriced compared to a stage, stand, LG CX, beoremote combo. You don’t get any additional features. B&O seem to have missed a trick in regards to the PL/surround sound capability - the Horizon did it!! Seems like a significant downgrade and a lazy decision to simply plug a stage into a LG tv and call it an “entry level” BeoVision.
Sandyb
Posts 2,186
Sandyb replied on Thu, Nov 19 2020 6:30 PM
It is exactly that - lazy.
Either lazy with respect to the included functionalities, or lazy with respect of pricing it similarly to their previous entry level TV.
That entry level TV had expansion capability, this does not.
Which is a shame, because in certain colour schemes it seems to look pretty nice.
Of course its meant to be stand alone TV - but in that case there are plenty of much better value propositions in the market, for half the price or less.
Sycamore:
Puncher
Durham
Posts 11,729
Puncher replied on Thu, Nov 19 2020 7:00 PM
Not wanting to start the "is it a beovision" thing again but watched "how do they do it" last night where they showed the building of a bv10.
No comparison, not even remotely! (sic)
Ban boring signatures!
matador43
Posts 1,373
One thing I wonder is, wouldn't the picture reflect in the frame when in low lit room?
I thought it was the reason why the frame in the BV 10/11/14 was beveled to the outside and the Horizon frame was dark.
The youtube video seems to answer this a little bit.
tuxian
Posts 5
tuxian replied on Thu, Nov 19 2020 8:17 PM
Any info on whether the "naked" Stage will work on its own, without the Contour Frame?
Mikipidia
Posts 2,169
Mikipidia replied on Thu, Nov 19 2020 8:29 PM
Yes it will, same as a stage, hdmi & cat connection.
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Nov 19 2020 8:36 PM
1990:
Wood + 690
In Sweden:
55.000:- any color incl textile front and any stand
65.000:- any color incl wood front and any stand
Steffen
Denmark
Posts 1,408
Steffen replied on Thu, Nov 19 2020 9:02 PM
moxxey:
Fansastic:
I wonder if the frame will be sold separately so we can benefit from a discounted LG panel through bulk suppliers
Also, does this mean the Stage is getting a wood fret?
You can get a wood fret for the Stage -although not from B&O (yet):
https://www.dba.dk/hoejttaler-bang-olufsen/id-1072322778/
andy_js
Englandshire
Posts 223
andy_js replied on Fri, Nov 20 2020 12:01 AM
The price would be fine if it included a motorised stand.
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Fri, Nov 20 2020 7:43 AM
Anyone already informed about the pricing of the Contour elements:
- LG CX48
- Stage without frame
- Frame
I tempted to get a LG48 upfront and later get the frame / stand / cover
mbee
Paris, France
Posts 1,842
mbee replied on Fri, Nov 20 2020 9:27 AM
@Fansastic: Please note that sometimes dealers are offering nice bonuses if you buy everything from them at once:
I've been notified by my dealer that if I get the full Harmony (incl. LG GX) B&O is offering 5 years warranty free of charge, and they have a very nice price on the 65GX. so don't hesitate to ask, you may be surprised.
Fansastic
Posts 768
Fansastic replied on Fri, Nov 20 2020 10:28 AM
mbee:
diisign.com
Thanks mbee, will check with my dealer!
beocool
Alankomaat
Posts 6,194
beocool replied on Fri, Nov 20 2020 11:49 AM
Just a few observations on the Contour
  • I like the fact that the aluminium actually looks like that. On the horizon it was always anodized black, which made it look like plastic.
  • It has more bulk, both visually and in actual dimensions, than the Horizon, not to my liking. It's a good deal heavier too.
  • The easel stand has gone by the looks of it. I very much dislike TV-stands and wall mountings as well, so sad to see that one go.
  • Sad to see there's no 40 inch version. I'm probably a minority of one, but 48 inches is too big for me. It's probably no longer feasible for B&O to cater for that market.
Vähintään yhdeksänkymmentä prosenttia suomalainen!
1990
Posts 521
1990 replied on Fri, Nov 20 2020 4:43 PM
@beocool
I hope STB makes an easel stand!
In any case it is hard to find a 40” LCD at all. Let alone a 40” LG with a chip capable of handling the B&O app. I guess a 40” won’t be in the cards. But remember that B&O now offers every OLED size that LG is making (48/55/65/77/88). 48 is pitched more as a desk top gaming screen than a tv. Times are changing.
beocool
Alankomaat
Posts 6,194
beocool replied on Fri, Nov 20 2020 6:18 PM
1990:
@beocool
You're definitely right. I just looked online and most offerings seem to be in the 55" and 65" size. The 40" TV's seem to have almost disappeared from the market. There are quite a few 32" offerings, though.
leosgonewild
Helsinki, Finland
Posts 2,373
I’d rather buy the LG oled GX 77” than this.
Sandyb
Posts 2,186
Sandyb replied on Fri, Nov 20 2020 8:06 PM
Not sure if you have seen John from Manchesters video on the Contour.
He says you cannot use a regular Stage and "make" a Contour.
Dont shoot the messenger.
moxxey:
Mikipidia:
Mikipidia
Posts 2,169
Mikipidia replied on Fri, Nov 20 2020 8:46 PM
I’ll try and find out more, maybe part of the removing of the alu edge damages it in a way that it’s not reversable?! Let’s see what i van find out
TWG
Posts 1,672
TWG replied on Sat, Nov 21 2020 9:00 AM
Is the OS still uncustomized and you'll see the flashy LG Web OS?
Page 5 of 8 (316 items) « First ... < Previous 3 4 5 6 7 Next > ... Last » | RSS
DigiCert Secured Site Seal
